Eclipse eyepiece for visual obs of eclispe with 80mm
5 replies to this topic
#1 Gert
Gert
Posted 27 January 2024 - 10:58 PM
Hi All,
I got this 80mm scope "SVBONY SV503 Telescope, 80ED F7 Telescope OTA with Focal Length 560mm, Compact and Portable Tube for Exceptional Viewing and Astrophotography" and plan to use it to visually observe the eclipse. It will be mounted parallel to other photographic equipment on the AP900 mount. What eyepiece would be a good match to see the inner corona, prominences in detail but yet still get the full eclipsed Sun? I am thinking something around 20mm FL and some wide field. What would be a good eyepiece choice?
Thanks & Clear Skies,
Gert
  • PrestonE likes this
#2 PrestonE
PrestonE
  • Loc: San Miguel de Allende,Mexico
Posted 29 January 2024 - 10:37 AM
Gert, visually the Corona is sometimes visible out to 5 or more Solar Diameters...
So, choose your eyepiece using a calculator like
https://astronomy.to.../field_of_view/
Preston
  • ShaulaB, Ohmless and JOEinCO like this
#3 JOEinCO
JOEinCO
  • Loc: Colorado Front Range
Posted 29 January 2024 - 12:44 PM
And a lot depends on your budget. Give us an actual dollar amount. waytogo.gif
#4 Gert
Gert
Posted 02 February 2024 - 01:49 AM
Hello All,
I found a Nagler T5 16mm in the classifieds and will try that out (once the rain stops in CA) There is the interesting story going about it that it is a scaled 1.25inch of the famous Nagler 2inch 31mm. Our club scope used the 31mm and it had excellent views.
Gert
#5 Sebastian_Sajaroff
Sebastian_Sajaroff
Posted 04 February 2024 - 08:39 AM
Corona is quite large 2° or 3°, you will see better with unfiltered binoculars. 8x42 and 7x50 are perfectly fine.
If you insist on telescope then a 32 mm Plossl.
Prominences are not that big, rarely larger than 1/20 of the solar disk. Choose an eyepiece that will show you the full solar/lunar disk plus a 20% margin around (0.8° to 1° field), an 8 mm with a 60° apparent field would be great.
#6 Sebastian_Sajaroff
Sebastian_Sajaroff
Posted 04 February 2024 - 08:41 AM
Safety tip : set an alarm to 30 seconds before third contact to put the filter back.
Totality is short and fascinating, time flies !
  • Diana N, Ohmless and jrussell like this
