Weather permitting I am planning to image the April 8 th total eclipse. I live on the central track.
It will be my second total eclipse. First was clouded out in 1997 in Cornwall.
I will be using a 80 mm ED f 7.5 scope with a Canon 3 Ti on tracked EQ mount. I have used it before on the 2017 USA event, although from my location it was VERY partial.
That was easy with a solar filter fitted and not needing removal.
However I am a little concerned that I might get the timing wrong for a total.
At what point can I remove the filter to capture the corona?
If there are Baillies Beads will it be safe? Can they cause any damage to the sensor?
In all the excitement will I forget to replace the solar film as totality ends and end up with a burned camera sensor?
Is there any advice on how to time and discipline myself to prevent damage? Digital alarm clocks, burning candles, water clocks, hour glass?
I am thinking that perhaps I should forget imaging and enjoy the spectacle only with eclipse glasses or filtered binoculars and kick myself afterwards that I have no images to remember it by ?
3m 27 secs is barely long enough to figure out the exposure times needed to capture the corona also.
I can hope to practice a few days ahead of time on a bare Sun but by all accounts the total itself is such an awe inspiring event that I might go to pieces.
What think Ye?
