So the imaging conditions here have been maddening In the downtime, I started work on an experiment. With the various recent discussions about deconvolution, I wanted to understand a bit better how much detail can be recovered from classical deconvolution. Unfortunately, my skills at RL are pretty bad and hence not representative. But I know that many of you on this forum are experienced at this so I am soliciting your help.
In https://drive.google...?usp=drive_link you can find an image of M101 in both fits and xisf format.
Here are the details about the starting image:
- Obtained from the Insight Observatory starbase database: https://starbase.ins...om/imageset/218
- Taken with PlaneWave CDK 12.5 f/8 scope and ZWO ASI6200MM Pro in the Utah Desert
- This is luminance only, 60m aggregate exposure
- Image scale is 0.307"/px and worst FWHM region according to PI script is 2.8"
Some details about the image provided:
- My image scale is about 0.85"/px. I resampled* one of my images to make it approximately the same image scale
- Used PSFImage on that image to obtain PSF.
- Convolved the IO image with my PSF to obtain the final image
- Worst FWHM region according to PI script is now 4.1"
* I have some concerns about this resample followed by extracting the PSF. But the resulting PSF looked the same in profile to obtaining it on the non-resampled image, just wider in pixels now.
What I am hoping to get is a few deconvolved versions of this image. The directory above should have write privileges for you to upload. Hopefully I can entice a couple of you to try your hand at it, if only for curiosity sake. Or sense of competition. Or sense of altrusim. Whatever works for you
I haven't quite figured out how to quantify "goodness" and will probably have questions about that. But my initial pass of this is just trying to see at a qualitative level what "good" deconvolution looks like compared to what I did.
Appreciate your effort and thanks in advance
Update: if you use PI, would be very interested in the deconv settings you used
Edited by sbharrat, 03 February 2024 - 02:53 PM.
