I took a look at your script. I'm concerned that you are relying on the execution time of each capture to align with the timing of the various phenomena. Even if under normal conditions the execution times do line up, it still means you have only one chance to start the script at precisely the correct time to have it execute those exposure times and ROI changes in perfect alignment with the actual event. I'd recommend using the "Wait until" or "Wait until later than" command, at least at the start, so that you can start the script with plenty of time before the event, and it will just wait until the precise time you specify to start executing. Better yet would be to add those times throughout.
Hi Jason, thanks for your comments, I appreciate them given we are all trying to make this work! I also saw Roberto's reply. Since we can't predict with total accuracy when events are going to occur in advance (those that occur near the limb pre and post totality in particular), even using specific timing triggers are an educated guess. Since the streams I'm taking are spread over time and with different exposures, I think I'll have a good chance of being on top of the event I'm trying to image. My main concern when I started looking at the script, was whether without specific sub timing triggers would it be consistent enough run to run. However, I've run it more than 25 times now, inside on the bench and outside attached to my telescope under the sun, using the power supplies, cables and settings that I'll be using on eclipse day. The capture sequence runs the same duration every time, plus or minus a second or less, over the 319 second duration. I am getting about 5150 16-bit images in the 19 SER streams during the run, with many different exposure durations set. Of course, with only one setup, I'm subject to equipment failure that day, but given the need to travel by air, one is all I'll take. I'm optimistic I'll get a reasonable image or two, but if I don't, then that is ok.
Edited by markmanner, 15 February 2024 - 10:26 AM.
