Thank you very much for all the explanations.
So, let's say that the 8-bit frame counter should read neither "0" nor "255". To avoid having the "dark" and "light" areas saturated. Ok, then I understand its usefulness
But in case of RAW16 setting, does the counter always refer to 8 bits?
Here are some other possible improvements:
1) If I click GALLERY, it only shows me the photo shots in the list, but not the .SER shots. Even if you have decided not to show the SER files, because they are not playable by the smartphone. You could show the name of the video file, so that you can delete it immediately. Without having to exit the app.
2) If I click "SAVE RAW", to take a first photo. After that, only "SAVE" appears in the rectangle.
3) When shooting video, can you add the duration on the display? If there is no space, you could delete the timetable
Regarding the ASI 120MM USB 2.0 version, i understand that the matter is complex. I also send an email to ZWO.
It's a shame not to be able to use it with the app, and to be forced to always use it with the PC.
Speaking of using this camera with the PC... I'm having problems! I hope you can help me, even if we're not talking about your app, specifically.
It doesn't work with many USB 3.0 ports, and I connect it correctly to the USB 2.0 ports. But even with USB 2.0 ports, there are problems!
Using Sharpcap and Asicap (pc version) with Windows 10, on two notebooks (USB 2.0 ports) the fps are half of those expected at maximum resolution!
If both the "TURBO USB" and "high speed" options are active, the fps increase until they reach the maximum expected ones. But they fluctuate a lot, until they drop to "0 fps" with max resolution! Dropped frames also increase! It happens at high resolutions with 8 bits of color, and at all resolutions with 16 bits of color. No problems with low resolution frames with 8 bit colors.
Instead, if I connect the camera to a USB 2.0 port on the desktop PC, and activate "TURBO USB" and "high speed". The fps speed reaches the expected maximum and remains stable, without oscillations and rare frame drops. With any resolution and color bit.
What could account for the fact that I have no problems with the desktop PC, and with the two notebooks, I do?
With the ZWO tool I verified that the firmware version is 3.0, and the possible updates found on the ZWO website are dated 2013! So, I don't think they are newer than the one already present.
ps: I would like to attach some screenshots, but I don't know how to do it on this forum, can you explain it to me? Screenshot from "postimage", it doesn't load them for me, it gives me an error.
Thank you
Edited by antarex, 12 March 2024 - 10:32 PM.
