For Fans of Classic Yamamoto (SYW) Scopes...
Cassegrain Classic Equipment Optics Reflector Refractor
44 replies to this topic
#26 jragsdale
jragsdale
  • Loc: Idaho
Posted 12 February 2024 - 05:20 PM
I’m converting mine over to alt-az. I got rings and a Vixen rail for it, made a stainless steel and aluminum handle, and plan to use it with my modern Japanese Sightron alt-az mount and tall wooden tripod. It’s also been converted to 1.25” with a Vixen visual back. It will be fun to compare it with my Takahashi FC-76. I plan to use it as an outreach scope when the moon is well placed. They are an impressive length and such a classic look. It will be fun to do some outreach solar white light viewing with my Lunt Wedge while we have a lot of sunspot activity. I figure folks would get a kick out of seeing it in action.
Gorgeous! I love the wooden legs on it, the black metal legs aren't very attractive (and are wobbly to boot).
  • Terra Nova likes this
#27 rcwolpert
rcwolpert
  • Loc: South Hutchinson Island, Florida
Posted 13 February 2024 - 11:37 AM
Once again my Mayflower 814, 815, and 80mm 816. I have since given away the 814 to a friend, who has basically ruined it. frown.gif   The 816 has the best optics of any telescope I’ve viewed through.
  • DreamWeaver, Josef1968, Exnihilo and 4 others like this
#28 Bomber Bob
Bomber Bob
  • Loc: The Swamp, LA (Lower Alabama)
Posted 13 February 2024 - 12:59 PM
Bob, that is one Tremendous Trio!!
I followed-along with your restore work eagerly -- and The Proof of your Labors is in the pudding.
  • rcwolpert likes this
#29 Terra Nova
Terra Nova
Posted 13 February 2024 - 01:06 PM
Thanks but those legs haven’t been on it for years. It’s back to the original metal legs. One difference is that it has a black metal Vixen triangulation tray which seems to add a little stability, (when legs and tray are locked tight with their wingnuts).
#30 Bomber Bob
Bomber Bob
Posted 13 February 2024 - 01:34 PM
Long Live this Yamamoto!
Whew!  I think my SYW 60 F7 finally has a Home:
Kenko SYW 60 F7 Beauty S02 - Mizar Yoke (FL LS).jpg Kenko SYW 60 F7 Beauty S04 - Mizar Yoke (FL RS).jpg
This MIZAR Yoke Mount suits it to a Tee.  Very smooth motions - a good thing as there's no Slo-Mo gearing.  Should be fine for low to medium powers.  Hoping to find that out this week.
  • deSitter, Terra Nova, rcwolpert and 1 other like this
#31 Bungee
Bungee
  • Loc: South Central Missouri
Posted 21 February 2024 - 11:17 PM
Since y'all are Yamamoto owners, I'll "ask" this here (I may have already answered my question).
My first views through my new to me 815 were disappointing to say the least. First with the supplied ep's, then adapting to 1.25's, I could only achieve focus at the lowest magnifications as the draw tube was racked all the way in. I set it aside for a while to sleep on it and concluded the glass had been tampered with.
This evening I took out the glass, marked it as it came, then flipped it and put it back. Kapow, now it works! I still used the 1.25's, but I can run through all sizes with phenomenal results. I even ran it up to 303x on the Moon with no disappointment. Out of a 6" drawtube, it only uses about the inner third, but it doesn't seem to matter.
So, my "question" is, did I do the right thing? I should add the objective clearly had been taken apart sometime in the past.
  • jragsdale likes this
#32 jragsdale
jragsdale
  • Loc: Idaho
Posted 22 February 2024 - 01:03 AM
Absolutely! Just make sure the spacers stayed put and check the Newton rings and collimation if you can. But if you got 300x+, you're probably on the money.
  • Bungee likes this
#33 Kasmos
Kasmos
  • Loc: So Cal
Posted 22 February 2024 - 01:05 AM
If it didn't work before, and it does now, you did the right thing.
  • Napersky, ErnH2O and Bungee like this
#34 Bungee
Bungee
Posted 22 February 2024 - 09:22 PM
Thanks for the reassurance. At this point I think I should just leave well enough alone.
#35 Werckmeister
Werckmeister
  • Loc: Europe
Posted 21 January 2025 - 05:50 AM
And another SYW Yamamoto Model CA-60. This one is labelled Denkar with the same label as the one from Brazil. Beautiful telescope. Two spacers were missing and the finder is not original. The hay is still fresh. Have not had the opportunity to use it yet.
Greetings
  • deSitter, Josef1968, mdowns and 2 others like this
#36 Astrokg
Astrokg
  • Loc: New Zealand
Posted 21 January 2025 - 08:14 PM
I have the same model, marketed as Sport Master here in New Zealand. It's a nice scope with pinpoint stars etc...
Edited by Astrokg, 21 January 2025 - 08:15 PM.
  • deSitter, mdowns, Kasmos and 2 others like this
#37 deSitter
deSitter
    Still in Old School
Posted 22 January 2025 - 05:24 AM
That looks very much like the casting and knobs on my Sears 6344, a 76/1200mm SYW scope. I would say the AO scopes with that spec are just a tiny bit better optically - not enough to matter on sky targets. The mechanics are superior to AO - it is lighter weight and has better castings.
-drl
Edited by deSitter, 22 January 2025 - 05:24 AM.
#38 LukaszLu
LukaszLu
  • Loc: Poland
Posted 23 January 2025 - 09:19 AM
Here is my example. This model has already appeared twice in this thread under different brands. Mine is marked with the MILO brand and differs from them in the design of the tripod. The tripod is made according to the design used with, for example, larger Royal Astro refractors - i.e. the lower element has a round cross-section. As for the appearance, this is my favorite type of tripod, pleasing to the eye with its elegant form. The paintwork is typical of older Japanese tripods - white base coat and transparent coloring varnish. However, the JTII sticker suggests that this is a specimen from 1973-1976.
Edited by LukaszLu, 23 January 2025 - 02:53 PM.
  • deSitter, mdowns, PawPaw and 4 others like this
#39 Werckmeister
Werckmeister
  • Loc: Europe
Posted 23 January 2025 - 03:24 PM
Yes, the rounded legs are very nice Lucas. Alas, my specimen's are rectangular.  It comes not with a JTII stcker but wit a cardboard lable, numbered F557054, perhaps 1970?
The wood wool in my box predates the styrofoam in yours I'd say.
It seems the SYW model CA-60 was availale in at least five continents, Africa may yet show up, Antarctica unlikely, Mr Yamamoto got around!
  • Bomber Bob and LukaszLu like this
#40 LukaszLu
LukaszLu
  • Loc: Poland
Posted 23 January 2025 - 03:50 PM
You're right, the styrofoam in the box also indicates that this is not the oldest version. From the previous owner's account, my specimen was originally purchased in Italy.
  • Werckmeister likes this
#41 Bomber Bob
Bomber Bob
Posted 25 January 2025 - 06:08 PM
IF the JTII round badge numbers are alphabetical...  your F could be circa 1960 -- my Sears 6336 started with a Y...
#42 Napersky
Napersky
  • Loc: Chicagoland
Posted 25 January 2025 - 07:41 PM
How do we know that the SEARS 6344 are made by SYW?
#43 deSitter
deSitter
    Still in Old School
Posted 26 January 2025 - 01:07 AM
It is marked on the little metal cover over the pinion gear. It is one beautiful OTA.
-drl
Edited by deSitter, 26 January 2025 - 01:09 AM.
  • clamchip, mdowns, PawPaw and 2 others like this
#44 PiSigma
PiSigma
  • Loc: North Carolina
Posted 26 January 2025 - 10:31 AM
Here's a pic of the stamping on mine, although they didn't stamp it very well.
  • Bomber Bob and jcruse64 like this
#45 Werckmeister
Werckmeister
  • Loc: Europe
Posted 26 January 2025 - 03:15 PM
Confusing business these stickers and badges! I came across a post you made about dating and badges.You are dead-on there as I have a Jupiter /Pentax badged #B7123 like on your badge and a date: 4. 4. 1956 as you proposed.
  • Bomber Bob likes this
Also tagged with one or more of these keywords: Cassegrain, Classic, Equipment, Optics, Reflector, Refractor
