I visited a bortle 2 sky last october in Northern Wisconsin, and a bortle 1 sky in Big Bend last week. Both under new moons. Both according to many websites (clearoutside.com, cleardarksky.com and the GOES satellites were perfect conditions. No clouds at any level, low humidity, no dust. Solid blue across the board.
It’s probably a result of my brain, but maybe you can help. I found the Bortle 2 sky in Wisconsin more interesting. Meaning, I think I saw more stars. It seemed more amazing. Northern wisconsin was at 600 ft. Above sea level, Big Bend was 4500 ft. Big bend has lower humidity and is desert, Wisconsin was forest, except out over the lake.
Could this be a result of an October sky with Andromeda at the zenith with Perseus and its surrounding areas blasting? In Big bend, andromeda was about 35 degrees and setting in the NW. The forest of Wisconsin blocked much of the views behind us to the west, whereas in Big Bend, it was mostly horizon to horizon except to the South with a mountain blocking views. I just didn't see much close to the horizon in BB but in wisconsin I remember seeing stars right off the dark lake to the East (Orion rising). Interestingly, I believe I was seeing a very strong zodiacal light in BB after sunset.
Could this be mind trickery or possibly very similar conditions where there was just more to see in an October sky? I don't know my sky, so not sure which season shows the most stars. This was all naked eye and binoculars only, no SQM meter, but I assume both were 22 (ish) since wisconsin was off season where most all locals are gone. Interestingly, I found Big Bend fairly populated now around Terlingua, without a forest, every bulb is seen for miles. We were far outside that area of local lights in that area.
Thanks for your help.
