Lunar this evening, and then Jupiter after dark. Moon was crisp, Jupiter showed a respectable amount of detail for the aperture. I'll post my notes in a separate message.
(6:31 PM) Sunset Moon is crisp. Had a little impromptu sidewalk astronomy session and showed two kids the whole Moon with the 22mm Kellner. (Didn't really focus on the Moon tonight, but last night I successfully used 200x to observe features like the southern craters, Tycho's tiered walls, structure in Bullialdus' central peak, and the shadow of Promontorium Laplace.)
(6:40 PM) Not much to see on Jupiter at the moment; the sky is still darkening and the GRS is not visible. Seeing is mediocre, maybe a bit below average, but the 3" aperture appears to cut through the atmosphere. Festoon activity subtly visible as patches on the underside of the NEB. Galilean moons are defined discs at 133x (9mm Huygens), even 96x (12.5mm Huygens). 133x seems to be the sweet spot for Jupiter, however I have nothing between 9mm and 6mm (200x).
(7:33 PM) Now that it's dark, contrast on Jupiter is better; very subtle turbulence is visible in the equatorial belts, and the patchy festoon activity is more apparent. No swooping trails like what can be seen with the 10"; unclear on whether this is because of the aperture, conditions, or the patches themselves simply not having trails. Admittedly the equatorial mount is growing on me. It's nice to be able to just sit in a chair and twist a knob to keep the target in view.
(7:46 PM) Satellite flew between Europa and Callisto.
(8:04 PM) Starting to be able to tease out features in the temperate zones. A slightly lighter band runs through the northern temperate region, and the southern temperate region is beginning to show the tiered bands and belts I see in the 10" so often. Not nearly as easy as with the latter scope, but present.
Wrapped up at around 8:45 because of the cold. Overall this scope is an excellent performer on the Moon, and a decent performer on Jupiter. With lunar, it seems to show most of what the 10" does, excluding kilometer-scale microdetail. It is more limited on the planets, and will surely be outclassed by the 10" on a stable night. The 3" and the 10" complement each other - the 3" as a quick-setup scope that works well under mediocre conditions, and the 10" as a powerhouse under good conditions.
Edited by monolithic, 21 February 2024 - 10:47 PM.
