I try to avoid Math, but to repeat myself...
Your View at the Eyepiece = Object + SEEING + Telescope SYSTEM + You!
With apologies for not avoiding math, and not to narc on you (this is nerdy), this good insight could be better conceptualized with multiplication:
Your View at the Eyepiece = Object x SEEING x Telescope SYSTEM x You!
This then means that there is an object to be seen. It is 100% out there in the sky.
If the seeing is 100% perfect, multiply by 1, meaning you see everything possible. If the seeing is imperfect (and it always is), multiply by less, with the result of degrading the 100% potential image.
Similarly with the telescope system. It either hypothetically shows you everything (no telescope actually does), or it degrades the view. Multiply by less than 1 to degrade the view. Smaller numbers degrade more.
Finally there is you. How skilled are you at observing? Multiply by 1 if you are good-like and see 100% of what there is to see. Multiply by less than 1 in proportion to how much your skills degrade the image.
In a perfect world with perfect optics and infallible astronomers, you see everything:
1 x 1 x 1 x 1 = 1
In the real world with its imperfections, you see less. As an example,
1 x 0.90 x 0.98 x 0.77 = 0.68
A good view, but less than 1; less than all of what we might have seen; less than perfect. The point is that we do not add and add and add to get our views; we avoid degrading the image that might be present, if only we did not diminish it through our best but imperfect efforts.
Edited by Joe Cepleur, 20 February 2024 - 07:11 PM.
