I found the useful website, which is here:
https://stjarnhimlen.../radfaq.html#11
and we can find there the values like this:
and this:
most of them like "Overcast sky" or "Twilight" and especially the lower table refers to the situation, when the solar apparent magnitude is -26.77.
What I am after is the same computation for the situation if our primary light source would have i.e. -25Mag, -24,5Mag, -22Mag and so forth.
I found some hint here
What's the conversion between apparent magnitude and lux?
and did some computations, however they refer only to the source of light itself. I am still unable to estimate the illumination for the twilight sky when the Sun is i.e. 6 degrees below the horizon, etc.
Moreover I would be interested in calculations of the sky surface brightness in various directions based on the stellar magnitude of the light source and its position against the horizon. Is there any (quite simple) formula? Which would calculate this stuff? In Stellarium when we click on the Sun, we have its apparent magnitude and the magnitude "reduced by airmasses". I would need the formula for it either if possible.
Any hint will be cordially appreciated!
