How many of you take out your telescopes and actively observe when ice crystals are falling from the sky? Last night was a case in point: close to -20*C not including the chill NW breeze, peering through cloud banks at the endlessly fascinating terrain of the waxing Moon (and Jupiter once the clouds cleared). Spend over an hour on the Moon alone. Ice crystals were falling from the sky in the first half of the session, quite thickly one point, though they never seemed to degrade the view to any real degree. A layer of icy white "dust" was visible in the moonlight on my black car and the black telescope case, accumulated on the sloping tripod legs, and around the bottom edge of the objective lens of my 95mm refractor. Once the session was over and I was packing up, I removed the OTA from the mount, inverted it, and tapped off as much of the "snow" as I could, but some stubbornly stuck in place. I ended up placing the scope in its case uncapped with a desiccant pack close in front of the objective, and when I opened the case this afternoon to check on things all moisture was gone without the slightest residue.
The experience got me thinking: am I alone in taking equipment out under such conditions or are there others here who will grab every opportunity to view something at night even under less than ideal circumstances when ice crystals are falling from the sky? For those who do, do you follow a similar routine of equipment aftercare or are there additional tips and tricks? Over to you guys.
