I thought I would post few words and impressions, but since it is a very new design, and lots of people will have many questions I decided to write down as many of my impressions in the first 24h since I got it. So here we go..
Package arrived from Sky Rover Optics (Kunming-China) very well packed (extra thick cardboard box, and with pretty well air cushioning around the product box on 4 out of 6 sides. I would suggest putting the padding on all 6 sides just in case. By the way, tracking was possible from start to delivery, with 11 steps of location progress updates, which was nice. Support was very helpful throughout as I already mentioned in the other thread.
Inside was a fancy product box which in itself has foam on all 6 sides, and the binocular is inside one of the best binocular pouch cases I have seen yet. Why best? Well, it's just padded and reinforced better than others while maintaining softness and light weight. I use those always when traveling, and in those pouches they are safe in my backpack or carry-on bag. Two straps for pouch and binocular, and a lens cloth.
The binocular itself really feels amazing in hand. Skin is medium gray olive green with satin finish. Very high end "Alpha" looking. Front caps are attached on the bottom which is new style to me. I like that system better than with the rubber ring around objective tubes like Nikon HG or Meade Masterclass, and many other.
Quality of build and mechanics seems truly top notch.
The Focuser:
Focuser is somewhat new (model) experience to me. It feels a bit dry while surprisingly smooth at the same time and very well performing. One would expect such focuser to be swimming in grease, but this one is not :-) The slight dry feel and absolutely zero backlash at any point or direction (even when digging for it in small back and forth movements) tells me it is a different mechanics from any I had before. The more I use it the more I like the confidence in its movement it provides. The more precise you want to go in small movements, the more it impresses in performance. Another reason I believe it is a different approach is the knob rotates while the "8x42 APO label in the center of it stays put so the text is always leveled facing you. Thats pretty cool. In comparison, my MMC feels much more greased up where you can even hear grease when going back and forth quickly. On contrary, my Zeiss Conquest HD was too sticky and just came back from Zeiss repair where they replaced the focuser due to it being too dry and sticky. It is way more precise now, but still a bit dry and ..well not sticky anymore but far from smooth like SkyRover performs. The old school EII Nikon is still something to beat, but this one is another breed that gives the same confidence in operation.
Rear elements are HUGE for a 42mm binoculars. You can see that next to my two "super wides" -The Nikon E2 8x30 8.8°, and the widest of all Tasco-110. 7x35 12.5°
The large eye pieces, as well as the accommodating prism system inside are the reason the whole binocular is a bit thicker by the rear end than your common 42mm Roof prism bino. It's quite an interesting design. It feels great in hand as such.
Looking on the inside of objective lenses I can see that all metal surfaces are painted and/or black anodized. No sign of prism joint line like in Kowa BDII case.
Eye cups retract in 5 steps which is another plus in my opinion as many have larger stops of two or three positions. Also a new feature to me as they have quite clicky solid stops. Some metalic action is involved. Being 5 positions you must take more attention that both are on the same level as it isn't as easy to see as in 2 or 3 step systems. However, it is more assuring than standard two or three steps twist cups that often have lots of in between play. In shape they resemble Nikon HG style eye cups, but are a bit less edgy and hence more comfortable to press on for me. Overall no complains there what so ever.
I will post my impressions here about the views as soon as I get some tests against the stars, and daylight. I have clear sky but seeing is very bad. Only quick views of the Moon and Orion were very interesting but lasted seconds at the time due to bad seeing. Views during day are very impressive and wide as I expected. I got that "wow" effect when tested it yesterday on a sunny day indoors and out the window. Wider and a lot brighter than my 8.8° Nikon EII. I will test and compare more to my EII and MMC as I have time, and will post Part 2 of the review here. Till then enjoy some photos and let me know if you have any questions.
Edited by Milos1977, 20 February 2024 - 11:17 PM.
