When you say GAIA spectra, do you mean the actual GAIA spectra and not the derived BP and RP?
Even so, have you read up on the full nature of the spectra?
They are relatively wide dispersion, quite wide, and very low resolution, not much better than the average amateur kit.
Also the brighter stuff in the catalogue may be ground based as bright stars are usually too bright for it (hence few having an accurate Gmag).
The red stuff starts about Halpha so most of it isn't optical, and the full stuff used for Gmag starts beyond blue and ends in the near infrared (somewhere in the Ic band range) so don't equate to optical. The blue stuff goes roughly optical, a little too blue to just past Halpha (the blue and red stuff overlap so even if people are playing with fluxes derived from the spectral continua that's to be thought of).
The radial velocity stuff is now used for the GRVS mag which is certainly in the near infrared and quite a narrow range of wavelengths.
In the end for any of these "transformations" being clever with spectral continua summations or even different filter bandpasses and deriving relations that way are very clever but inherently so much juggling of maths with software.
What is really needed to equate filter bandpasses is to plot the things against each other. You find yourself a primary source of Johnson B and V and possibly Rc (Cousins R, probably B and V will suffice, and if you can't find B AND V many sources of V and B-V exist so you can get B) standard or secondary standard magnitudes. You cross correlate those to the GAIA catalogue (try CDS XMATCH service, websearch) on about an arcsec or two astrometric matching, then you simply plot things against things on a graph. You can check the linearity of the plot (eg GAIA BP versus B and even V), derive a relation (no need to go mad, quadratic is often overkill, linear gradient with intercept will suffice). Then you take your Johnson V or B mag or pick eg the GAIA BP mag and use that relation to derive the other values. Then you take the difference, the residuals, of the observed (catalogue mag) and the calculated (derived) magnitude for the passband of interest and get the residuals. For example Johnson B(standard) minus Johnson B(derived from BP).
Then you have a look at the scatter, derive the standard deviation, mean and median to see if the first is small enough to feel good, and the second and third are sufficiently near zero to suggest no real systematic offsets.
Then you plot the residual values as a function of B-V (or BP-RP) to see if there are colour dependencies of the transformation.
You can also plot the derived Johnson B against B-V to look for colour dependencies to the transformation (does it 'bend' or get broader at the red end, for example).
You should also plot the derived magnitude against the observed magnitude to see if there is a magnitude dependency as the faint end not only usually broadens out (increases spread) but often has a bias in one direction, a well known threshold effect (you will likely not be going to either the Johnson photometry source catalogue nor the GAIA catalogue limit so you may be spared this.
To see an example of threshold effects look up Malmquist Bias (it is an astronomical topic). Or think of the quantum vacuum versions. The former is covered well enough in wikipedia, the latter is of the ilk that at a threshold level of measurement based on energy you can get over representation at the limit, such as virtual pairs of electrons and positrons at the quantum vacuum limit where a pair instead of rejoining and turning back to gamma rays somehow the energy is found (interaction with real matter or magnetic field or electric field etc) to make one of the particles real, and these appear as a surplus on top of the nonvirtual (real) particles. The Malmquist Bias will be a better read than my lame explanation.
Remember also that the GAIA system derives Teff from a very complex somewhat assumption laden model, which gets changed every data release.
Also, and most important, all data releases of GAIA so far have been optimised for FGK stars. It says that in all the paper work. For A and M stars completely different relations will likely be used as opposed to extrapolations of the FGK model and the non-continuum lines will differ markedly (albeit early F has some A type spectra characteristics at the Balmer end).
But check data against data not just from physics first principles and juggling formulae based thereon.
EDIT finally found this, I can never remember what to call it so websearch is tricky https://vizier.cds.u...?-source=II/374
That can also be used via CDS xmatch, just enter II/374/table2 as the source and upload a table of targets (with ra and dec first two rows) or choose one of the many VizieR photometric catalogues. Possibly of more interest to yourself though may be the paper behind it. For that you'll need to go to arxiv.org and search on the title of the catalogue (same as the paper title). It was written and published in a technical venue, not an astronomy periodical.
Edited by yuzameh, 25 February 2024 - 11:17 AM.
