If you are willing to do some sleuthing for used Denk components, you can have a wonderfully flexible bino-viewer set up.
A little known secret, one I mentioned to Ed, was to thread the OCS element directly into the 2" nosepiece of the PowerSwitch. See the picture.
This reduces the power switch magnification levels to about 1.15X, 1.7X and 2.5X (depending on the OCS) and less out travel is needed to reach focus for refractors and Cass's. Give it a try. You should be able to reach focus in the mid and high power modes, but, with some refractors, you may not have enough in travel to reach focus in the low power mode. But you might, so, again, give it a try.
The other secret is more historical. There are actually two versions of the "Multi-Purpose" OCS. One was/is called the low power OCS (1.3X) and the other the high power OCS (1.4X). They carry the same labeling on the side of the OCS, and look basically identical, except that the OCS element retaining ring for the "high power" unit is almost flush with the top of the cell. The retaining ring for the "low power" unit is recessed about 1/8" from the cell's top. I have both and I have a lot of flexibility in customizing my power switch configurations to specific scopes and uses. Highly recommended.
Jeff
