Okay folks, you've been very helpful and I appreciate it as I frantically try to catch some decent pictures of what will certainly be the last North American eclipse I ever see... 2017 was amazing in Casper and I want to do better this time.
My goal is for a laptop to control the camera while my Star Adventurer (at least mostly) takes care of alignment. To that end I've requisitioned a MacBook from work to run Eclipse Maestro and rented a 500mm Nikon prime lens with a Nikon 1.4x teleconverter. That puts me at 700mm on a full-frame camera.
Side note re earlier post: I did talk to Nikon today and they told me since the equipment is all theirs and matched up, I WILL be able to specify a desired aperture, even in manual mode, and the camera will not offer one that the attached lens and converter can't deliver.
There is a non-zero chance that I won't be able to polar align the night before. This is mostly owing the the fact that I need to sleep and don't necessarily want my mount and tripod sitting out in the parking lot of a state park overnight. I might be able to get up early but let's assume I can't or that I need to move because of clouds.
Anyway on to my actual question regarding polar alignment:
If align my Star Adventurer w/ Equitorial Wedge in the morning using an app like PSAlign to get *roughly* on the NCP and then start tracking the sun, then use the Declination and Azimuth adjustments (not RA) to re-center the sun periodically (say, every 15 minutes), am I correct in thinking that this will bring my mount into better polar alignment? Seems like Declination will only need to be adjusted once and it might take a few tweaks on azimuth.
I was just going to try it but it's been cloudy.
Maybe I just need to spend a few nights practicing on the moon to see if my assumption is true.
Or am I totally off base?
Edited by mdredmond, 27 February 2024 - 10:20 PM.
