Sharpstar 150HNT - removing correcting lens to collimate?
3 replies to this topic
#1 Cinnamon
Cinnamon
  • Loc: SW Ontario Canada
Posted 28 February 2024 - 12:54 PM
Hello,
I own the 150HNT, and the collimation instructions recommend removing the corrective lens in the focus tube to collimate the scope. It screws into a tube that goes onto the focuser, so you need to unscrew the lens from inside that tube(reassemble and then laser collimate). Mine sits about 6-7 mm below the top of the tube it is recessed into.
Two questions:
1) Is the depth that the corrector screwed into this tube important? If so, I will have to measure it accurately.
2) What is the best way to remove it? I have a spanner wrench, and I have put a decent amount of force on it, any more, and it slips, and I'm terrified of scratching the lens. I gave up trying to remove it and laser-collimate it through the lens, which they don't recommend.
Any tips on getting that thing out?
Thank you
Scott
#2 dan_h
dan_h
Posted 28 February 2024 - 01:26 PM
https://www.bing.com...age&form=rc2idp
#3 Cinnamon
Cinnamon
Posted 28 February 2024 - 01:36 PM
Thanks, that's a lot better looking spanner wrench than the one I have.
#4 OregonAstronomer
OregonAstronomer
  • Loc: Central Willamette Valley, Oregon High Desert and remotely from New Mexico
Posted 28 February 2024 - 02:23 PM
I have the same scope. When I misplaced the tool that came with it as shown in dan_h's picture, I ordered this one from Amazon:
https://www.amazon.c...,aps,265&sr=8-3
The position of the corrector lens does matter in order to achieve proper back-focus. If you need to adjust the back-focus by a tiny amount, you can actually do so by screwing the lens in a little farther or backing it out a little.
Arnie
