For anyone going out to dark sites, here's my flashlight setup recommendation. It's red light only so you don't have to worry about accidentally hitting a white light button, and it's dimmable. You can use the headband to wear it when you need both hands, and you can easily take the headband/flashlight off your head to hold and point at the ground while walking around.
Flashlight
https://www.amazon.c...e?ie=UTF8&psc=1
Flashlight Headband
Rechargeable Batteries
https://www.amazon.c...le?ie=UTF8&th=1
Battery Charger
If you use a bright, non-dimmable LED headlamp please understand that you are probably annoying like 99% of the people around you.
I also recommend using small pieces of black electrical tap to cover anything that emits light, on things like: power supplies, mounts, cables, power strips, etc.
And use sheets of this, 2 or 3 layers if you need to, to cover screens:
Just cut an oversized sheet and tape it down.
Edited by Matt0011, 12 September 2024 - 03:14 PM.
