Hello,
I don't have a full frame camera to show corners on that. Currently I use a Canon Rebel T8i (22.30mm x 14.90mm sensor).
Here is how stars look in the corners at full res using Aberration Inspector in PixInsight on an image that was just screen stretched and nothing else.
Sigma 28mm f/1.4 art lens wide open at f/1.4. Untracked 5sec exposure at ISO 3200.
Source image for comparison:
Overall I think it is a great lens. There are some aberrations when running it wide open. To my eye the star shapes are not noticeable once an image is resized for normal viewing. There is some vignetting and I sometimes use ABE or DBE to help with that.
I expect a full frame camera wouldn't do as well.
Thanks so much for the info and image. Yeah, those corners don't look too bad for wide open 1.4 and when downscaled a bit the blocky stars will look better (atleast they don't have big wings or something). However its a bit concerning thinking about how much more it will degrade over a full frame.
Now I have plenty of crop frames as well (7DII is my main camera), so I don't have to use full frame. But I hate to give up the wider framing when I have the option.
So I guess there are some more things to consider. The Sigma 28/1.4 definitely is on my finalist list. I could just use it on my 7DII, or 6D + crop it if it gets too bad.
Would it be worth stopping it down to get better full frame corners vs wide open and cropping?
Or would there be a better contender for full frame coverage?
For something cheaper like the Samyang lenses, I had even thought about a pair of them, running dual cameras and lenses to cover a wider view, and stitch the images together. I have two 7DII bodies, and wouldn't be opposed to also picking up a second 6D for dual full frame cams, they can usually be found pretty cheap nowadays on ebay. However two Sigma's might be too $$ for me just as hobby, so probably won't do that. But just something to keep in mind, instead of trying to spend more for one good full frame lens, for the same price maybe two Samy/Rok shooting together would do as well or better? I could machine a bracket to mount the cameras in an appropriate position. Thoughts?
