I need to take an automated series of 7 shots with shutter speeds from .001 to 1 sec. Sony A6000 will do 11 FPS in continuous drive mode but, in a NINA sequence taking a shot at one speed, taking a second at another speed, etc., NINA hangs with the message "camera did not set image as ready after exposure time +60 seconds." That can be worked around but inserting a 2 second wait into NINA sequence between each shot. But, using NINA, it takes a little over a minute to loop through one sequence of 7 shots. It doesn't seem to be a NINA problem as the camera is just taking it's time to write the file to the SD card.
Continuous (burst) mode provides the speed but it's manually press the shutter, guess how many shots, manually release the shutter to stop, change speed, and repeat. I can't help but think there is a better way but I just don't have the Mojo (yet).
The desire is to take 7 shots with different shutter speeds and repeat the loop. Any ideas?
