S&T Review of TMB's Monocentric Eyepieces
#1
Posted 17 June 2004 - 08:19 PM
If so, any comments?
Walter
Thread:
#2
Posted 18 June 2004 - 07:25 PM
#3
Posted 18 June 2004 - 08:25 PM
#4
Posted 18 June 2004 - 08:33 PM
#5
Posted 18 June 2004 - 08:59 PM
#6
Guest_**DONOTDELETE**_*
Posted 19 June 2004 - 11:02 AM
#7
Posted 19 June 2004 - 11:31 AM
I think I'm gonna stay with my Univ. Optics Orthoscopics, and keep my money.
Yeah! No kidding. A 32* AFOV for $250????
#8
Posted 19 June 2004 - 04:50 PM
Monocentrics are intended for planetary observation, where field of view isn't a major consideration.
Dave Mitsky
#9
Posted 21 June 2004 - 04:53 PM
:money: :money:
#10
Posted 21 June 2004 - 05:13 PM
#11
Posted 21 June 2004 - 08:37 PM
#12
Posted 21 June 2004 - 09:07 PM
#13
Posted 22 June 2004 - 09:39 PM
#14
Posted 22 June 2004 - 10:10 PM
Personally, I thought the Supermono I bought enjoyed the expected strength of low scatter and also excellent sharpness across the field, albeit with noticeable curvature and some lateral color in my 10" f/5 Newtonian. At first the members of the TMB group protested that they saw no lateral color and no field curvature and that maybe I had a defective one, yada yada yada. But when I hooked up with another owner with the entire initial set and the same type of scope and verified the exact same properties in his scope with his TMB SuperMonos, which were checked by TMB himself, Thomas explained that there might be some lateral color in fast scopes... If he hadn't, I expect many of the people in the TMB yahoo group would never have accepted that ANYBODY saw lateral color (let alone field curvature--which is now also widely reported in fast scopes) in one of these eyepieces without the eyepiece being defective.
#15
Posted 23 June 2004 - 05:11 AM
The first 5mm TMB I got wasn't very good. It had plenty of astigmatism off axis and plenty of field curvature (at f/7.7 or f/6.25). I wasn't very satisfied so I went to my dealer, exposed the problem, and was offered to select the best 5mm TMB I could find. Two more 5mm were available and both had much better performances, as off axis astigmatism was imperceptible and field curvature invisible at f/6.25 (I must point out that the perception of field curvature will depend on the age of the viewer: the older you are, the more likely you are to detect field curvature if no specific test is made). Basically, a good 5mm TMB performs very well, but I will check this as soon as I find a 5mm Clavé and will definitly pin it against a 5mm Pentax XW (Just for fun). There is (was?) obviously a quality control problem with TMB eyepieces, as other colleagues reported similar problems. That's unacceptable for such an eyepiece.
#16
Posted 23 June 2004 - 10:22 AM
So, I'd put a safer lower limit for monocentrics at f/7. Since the eyepieces available are shorter focal lengths, I'd expect them to do well in telescopes of f/8 or longer (most commercial SCT's, MCT's, Cassegrains, and many refractors), but not the Dob or Wide-View refractors. And, judging from the responses, this seems to be the case.
My question: Most eyepiece designs do very well on axis (e.g.planetary viewing), so given a "planetary" scope, can we be expected to see the difference between two eyepieces with a different number of lenses if they are both well-made?
This is a rhetorical question, not designed to incur the wrath of the monocentric groupies.
But I do wonder if the monocentric debate isn't a little like the super-high-end amplifier debates, in which the quality of the expected "sound" of a given amplifier seems to be directly in proportion to its price and reputation.
I've looked through a lot of eyepieces through a lot of scopes in 41 years of viewing. My only laugh is that the monocentric eyepieces are as expensive as they are. Compare a good Orthoscopic with the Monocentrics (which should be less expensive to make), and you get the idea. After all, the Nagler 6 eyepieces are cheaper than the 4's and 5's because there is less glass. By those standards, the Monocentrics should be about $50. That they are >$200 says more about the purchasers than the eyepieces.
And if there is a QC problem with them? Well, caveat emptor.
Don
#17
Posted 23 June 2004 - 12:14 PM
#18
Posted 23 June 2004 - 05:29 PM
Nevertheless, I found it superb on the Moon. It gave better views than a TAL 7.5mm Plossl, which is supposed to be a very high performing budget eyepiece. This is in spite of the 7.5mm being more in the realms of realistic magnification for my scope. The TMB was pin sharp edge to edge, with no flare or reflections. I found the narrow field and 'looking down a tube' presentation was actually very well suited to concentrated observing, and as such more useful than the 'wow' view offered by wider field eyepieces.
Earlier, in daylight, I was able to directly compare a TV Radian with the TMB. I thought the Radian provided a more 'pretty', 'fall in' view, but the TMB offered the best definition of fine detail and colour fidelity. The TMB clearly gave the brighter, sharper view with the most contrast.
It would be rash to draw a conclusion after such a brief period of time, but being rash I would say that an eyepiece like a TMB mono is a 'serious' tool for 'serious' observing. It's not something to impress the neighbours with, it's something to sit down and get on with the job with.
Since I haven't tried UO Orthos, I cannot comment on the issue of whether the TMBs are worth the extra over those. I'm not prone to 'product loyalty', I don't own a TMB, and I can't currently afford one. This is just my two cents to say that in my brief encounter with one, I thought it was really rather good.
#19
Posted 23 June 2004 - 06:39 PM
As a deep-sky afficionado, I desire eyepieces that can be used for both so that I do not have to afford to have multiple sets of high-end eyepieces. That means a type of eyepiece that is good on Saturn, AND the Omega Nebula AND NGC2024 all at the same time. This means, apparently, that a compromise must be made from the standpoint of the planetary observer--a compromise perhaps in absolute fidelity, but not a compromise in utility.
When I try to get a newbie interested in the sky, I almost never show him the planets. It's not because I don't get a good view, or because I don't think he/she would enjoy it. But because seeing is rarely good enough for high-resolution views of the planets, and because deep sky objects can be wonderful even when seeing is mediocre, and because I want the newbie to be involved in more than just the viewing of the 10 brightest objects, I usually recommend scopes that are general-use scopes, not specialty planetary instruments. Likewise, I recommend eyepieces that fall into the same category. So I exclude Orthoscopic and Kellner and Monocentric eyepieces and extol the virtues of Plossls and the like. They may not be perfect for ALPO members, but they provide a more engaging view of the sky through a telescope. I don't want to live in a world where everything is a general-use item, but neither do I want to see all beginners give up on the deep-sky without even trying.
For one thing, instead of getting angry enough about light pollution to want to do something about it, such scope users tend to put up with it because their planetary images aren't damaged as much by the lights.
And I want us all to be angry about it so that things change for the better.
I suppose, in the final analysis, when one says this eyepiece is better than that, we should not ask "How?" but "For what use?"
Don
