After finally figuring out how to remove the clamshell from my vintage SV85S, I measured the tube for mounting rings. I just want to make sure my calculations are correct and confirm the size of rings needed.
The circumference of the tube is 11.125 inches or 285mm, both measured. So to get the diameter of the tube, I divided each number by 3.14 9 (Pi) and got 3.54 inches (89.92mm by conversion) or 90.76mm by calculation. So I would need 90mm rings. Right?
Math was never my strong point.
