ES argon-purged pressure test?
11 replies to this topic
#1 Rigel_10
Rigel_10
  • Loc: Arkansas
Posted 02 March 2024 - 11:47 PM
The idea of argon-purged eyepieces is a fantastic design and offers protection from mode moisture, etc invading eyepieces but...
Is there anyway to test whether the seal is still holding or has failed someway? The design has been around a long time, are the eyepieces guaranteed to never lose their pressure seal?
#2 Ernest_SPB
Ernest_SPB
  • Loc: St.-Petersburg, Russia
Posted 03 March 2024 - 01:54 AM
Try to put the eyepiece into a fridge and check then how much moisture will be seen inside... :)
  • PKDfan and jlinsobe like this
#3 beggarly
beggarly
  • Loc: Belgium
Posted 03 March 2024 - 04:26 AM
Read this thread: https://www.cloudyni...inium/?hl=argon
#4 PKDfan
PKDfan
  • Loc: Edmonton
Posted 03 March 2024 - 05:26 AM
I find it almost IMPOSSIBLE to believe that Argon would not eventually all leak out.
Eventually.
CS
#5 Rigel_10
Rigel_10
  • Loc: Arkansas
Posted 03 March 2024 - 09:43 AM
Eventually.
CS
Agree, rubber O-rings do fail, just look what happened to the space shuttle.
Expansion and contractions happen, but how long before it takes place?
#6 Jon Isaacs
Posted 03 March 2024 - 09:53 AM
The Space Shuttle failure was the choice of the wrong material, it failed catastrophically.
The loss of pressure in an eyepiece is the result of the Argon diffusing through the O-ring material. Argon is relatively large and diffuses relatively slowly which means very, very, very slowly.
I have one Explore Scientific argon purged and sealed eyepiece. I opened it up to add cross hairs... It's no longer filled with argon.
  • sevenofnine likes this
#7 sevenofnine
sevenofnine
  • Loc: Santa Rosa, California
Posted 03 March 2024 - 06:45 PM
From the Explore Scientific website, their eyepieces are tested by submerging them down to 1 meter of water for 30 minutes. That's a pretty good final Q/C test IMO. You could test your eyepiece by doing the same borg.gif
Edited by sevenofnine, 03 March 2024 - 06:50 PM.
  • Rigel_10 likes this
#8 Ernest_SPB
Ernest_SPB
Posted 04 March 2024 - 02:04 AM
In case of leakage they can reject an eyepiece with defect.
What are options for eyepiece owner after negative result of the test?
#9 archer1960
archer1960
  • Loc: Southern New England
Posted 04 March 2024 - 07:21 AM
Take it apart, dry it out, reassemble it, and start using it...
#10 pregulla
pregulla
  • Loc: Israel
Posted 04 March 2024 - 07:34 AM
You may try cooling it in a fridge for a while, then placing into warm water. If there are leaks the expanding air will create bubbles.
#11 Rigel_10
Rigel_10
  • Loc: Arkansas
Posted 04 March 2024 - 08:11 AM
I have seen ES (82 series) eyepiece sold without the argon gas treatment for a cheaper price. I'm guessing these EPs failed the test and were then sold as-is with no gas?
  • archer1960 likes this
#12 pregulla
pregulla
  • Loc: Israel
Posted 04 March 2024 - 08:40 AM
Maxvision have different nosepieces than ES versions. My guess they had a shortage of barrels/seals so they took some off their Bresser lines to make non argon purged versions. But who knows...
