Flats seem to dim? (Lumix S5)
40 replies to this topic
#1 Whereisclearsky
Whereisclearsky
  • Loc: UK, South-west England
Posted 03 March 2024 - 03:57 AM
I'm using Lumix S5 with Sigma 40mm F1.4.
My flats seem too dim even though the histogram is way to the right, like the peak is outside histogram.
Here is what ADU values I get with 1250 ISO, F2.2 and 1/250s:
https://i.imgur.com/uGeIP02.png
Do I need to get them much brighter?
#2 Tapio
Tapio
  • Loc: Tampere, Finland
Posted 03 March 2024 - 04:33 AM
Just use them (+bias) in calibration.
If they correct vignetting and dust motes they are fine.
  • Whereisclearsky likes this
#3 Whereisclearsky
Whereisclearsky
Posted 03 March 2024 - 04:36 AM
I don’t know if they will that’s the issue.
I’m afraid they might be too dim.
#4 sharkmelley
sharkmelley
  • Loc: UK
Posted 03 March 2024 - 04:41 AM
Your flats are absolutely fine.  You are overlooking the fact that you have a 14-bit camera, so when you import the data into PixInsight the values will all be in the range 0-16383.  In other words, 16383 (or thereabouts) is the saturation level and you want your flats to have a mean value of approximately half of that i.e. 8000
#5 Whereisclearsky
Whereisclearsky
Posted 03 March 2024 - 04:53 AM
Should I take lights+flats+flat darks or replace flat darks with bias?
#6 sharkmelley
sharkmelley
  • Loc: UK
Posted 03 March 2024 - 05:01 AM
Flat darks are not necessary for DLSR/Mirrorless cameras.  Use bias frames instead.
#7 Whereisclearsky
Whereisclearsky
Posted 03 March 2024 - 05:05 AM
Btw I have seen your older thread where you made script for Nikon concentring rings,
so you think it would be possible to do for Lumix S5?
#8 sharkmelley
sharkmelley
  • Loc: UK
Posted 03 March 2024 - 05:49 AM
The script I wrote was designed as a repair to data affected by a specific fault in Nikon's lossy data compression.
It's not yet clear to me what kind of raw processing causes the Lumix S5 rings
Edited by sharkmelley, 03 March 2024 - 06:06 AM.
#9 Whereisclearsky
Whereisclearsky
Posted 03 March 2024 - 06:33 AM
It annoys me that I don’t know what settings to go for exactly to avoid the rings.
Do you think I could do some test lights without having access to sky/stars?
#10 sharkmelley
sharkmelley
  • Loc: UK
Posted 03 March 2024 - 06:55 AM
My general advice for working around problems with coloured concentric rings is to shoot at a relatively high ISO (e.g. ISO 1600 or greater) and adjust your exposure time so the peak of the back-of-camera histogram is approximately halfway across.  Flats should be shot at the same ISO and with the back-of-camera histogram further to the right.
#11 Whereisclearsky
Whereisclearsky
Posted 03 March 2024 - 11:43 AM
With 1600iso and 1/2 histogram wouldn’t some objects like m42 be overexposed?
#12 sharkmelley
sharkmelley
  • Loc: UK
Posted 03 March 2024 - 12:40 PM
Almost certainly if you expose so the histogram peaks halfway then M42 and other bright objects will be overexposed.  But it's quite normal for the core of M42 to be blown out, even when shooting "normally".  Most people combine the blown out exposures with a set of much shorter exposures that don't blow out the core.
#13 Whereisclearsky
Whereisclearsky
Posted 03 March 2024 - 12:42 PM
#14 sharkmelley
sharkmelley
  • Loc: UK
Posted 03 March 2024 - 12:45 PM
You will use only the bright core of the less exposed images.  That's the way it's usually done.
#15 Whereisclearsky
Whereisclearsky
Posted 03 March 2024 - 12:48 PM
I know I asked before but do you think I could try replicating the rings
without access to clear skies?
Like maybe shooting a black large sheet or something.
#16 sharkmelley
sharkmelley
  • Loc: UK
Posted 03 March 2024 - 12:56 PM
Yes, you can shoot flats at different exposure levels and at different ISOs to replicate the rings.  That's exactly how you helped me diagnose the original problem in this post.
#17 Whereisclearsky
Whereisclearsky
Posted 03 March 2024 - 12:59 PM
I meant shooting lights like that to see what ISO and shutter speeds doesn’t produce rings.
This camera btw has dual gain iso but I doubt it has anything to do with it.
#18 sharkmelley
sharkmelley
  • Loc: UK
Posted 03 March 2024 - 01:11 PM
OK, let me rephrase what I said.  Yes, you can shoot flats at different exposure levels and at different ISOs to replicate the rings determine what ISOs and histogram levels don't produce rings.
#19 Whereisclearsky
Whereisclearsky
Posted 03 March 2024 - 01:20 PM
But if I try to do 30s long flat at higher iso it will be way overexposed right?
#20 sharkmelley
sharkmelley
  • Loc: UK
Posted 03 March 2024 - 01:25 PM
It's not the exposure length that matters.  It's the position of the back-of-camera histogram that's important.
#21 Whereisclearsky
Whereisclearsky
Posted 03 March 2024 - 02:15 PM
I have tried shooting some flats at multiple ISO and exposure times to keep the histogram peak in the middle.
Would you be able to take a look please?
https://mega.nz/file...tXzLXbbLJeAirx0
Or at least explain how to do it? I read your previous posts but I'm not understanding lots of it. lol
#22 sharkmelley
sharkmelley
  • Loc: UK
Posted 03 March 2024 - 03:39 PM
Sure, I'm happy to take a look.
#23 sharkmelley
sharkmelley
  • Loc: UK
Posted 03 March 2024 - 05:36 PM
Was the back-of-camera histogram central? When I open these in Photoshop, the histogram is well over to the right - about 1/4 from the right-hand edge.  Maybe there's a difference between the way the Lumix S5 renders the data compared with Adobe's engine.
In any case, the good news is that none of these images had any hint of rings and the histograms didn't have the same regular spikes.  I think you can go 1 stop lower in exposure and still avoid the rings.
#24 Whereisclearsky
Whereisclearsky
Posted 04 March 2024 - 04:10 AM
Yes the histogram on camera's display was always around the middle.
Here is how Apple Photo's sees it: https://i.imgur.com/DsmlxYA.png
As for flats I should try to target 8000ADU right?
#25 Whereisclearsky
Whereisclearsky
Posted 04 March 2024 - 04:24 AM
Also I wonder why at one point the histogram peak goes white instead of yellow?
https://imgur.com/a/1Ot3QO0
I have also tried 2 darker flats if you don't mind looking, these surely should have rings, otherwise I would be really confused. grin.gif
https://mega.nz/file...RNWzmRaSRL-V3j0
