Like betacygni, I too have had the Clicklock let BVs slip and my own recommendation is to go with something with three clamping screws and my recommendation for binoviewers is this specific visual back. This is the only thing I trust for using a binoviewer on small SCT that is GEM mounted.
https://www.astro-physics.com/adasct
Now there are three screws, and it is incumbent on the user to ensure that all three are tight, but the knobs are a good size to allow getting good pressure, and the three contact points provide the absolute best grip you will get on the nose of a 2" diagonal short of doing custom modifications. Astro Physics used to sell the Mark V, and they know what it takes to hold a binoviewer.
The 3.25" version for the C11 and C14 was likewise the only one I would recommend for these larger scopes. This is the best C11 and C14 visual back made, bar none. Note the large diameter of the thumb Screws. This might be an upgrade you can make to your existing diagonal if there is space to allow for the diagonal rotation due to the large diameter of the thumb knob.
https://www.astro-physics.com/adasctlc
The problem with the 8SE is that it will only really accommodate the C8 or other small SCT and you don't get the ability to use it with your refractor. I would only recommend them if you can't afford anything better.
While I have in the past recommended the Mini-Tower Pro, or even better, the Az Mount Pro (which is what I use today), these days, I would recommend getting a strain wave mount like the AM5 or the HAZ31. I often think about replacing my Az Mount Pro with an AM5, but I am waiting for more competition in the market. The AM5 works in both GEM and Alt Az mode, so if you were going to image with it, this would be a better choice than the HAZ31, which might work on a wedge, but was intended specifically as Alt Az. These days, I would say that the AM5 would be my top choice, though I would lose some of the features of the Az Mount Pro. With any of these mounts, unless your mount is a pier mount, you would need a semi-pier.
I use the Az Mount Pro though, and I like. I really like the built in rechargeable battery and wi-fi. While it is not super stable with my 130mm refractor, I find it to be good enough for my own needs.
Anyway, if your budget allows, get a mount that can accommodate your refractor tool. For any of these, you would likely need a semi pier for the refractor but all of these mounts are very light. Personally though, I would stretch the budget and save as necessary to get a strain wave mount.
Edited by Eddgie, 04 March 2024 - 08:51 AM.
