I bought a WO binoviewer last fall but hadn't got around to using it very often. I used them on my C5 and the view was nice, but recently I put them on my C9.25 and this provided a brighter image, which was at least as good as I was getting from my 127mm binocular telescope.
Rick
You may not have realized it, but unless you use a Barlow or a GPC, there is really no configuration using a standard visual back that will give full aperture when using a binoviewer with the C5. Even with the T2 diagonal unless you are using the 10mm visual back, the aperture is reduced to 118mm
Using a standard 1.25" diagonal and visual back is is reduced to something like 96mm.
Also, when you reduce the aperture, since the secondary does not get smaller, the percentage of the secondary obstruction becomes quite large.
For your C9.25, despending on your configurations, you could also be losing some aperture, but since you have so much more than the C5 to start with, you are still going to get a much brighter view. Keeping the light path short on a C9.25 is important though but there are configurations that give full aperture.
Edited by Eddgie, 05 March 2024 - 10:11 AM.
