We've posted the dimensional data. Whether it is "a problem" or not depends entirely on the scope, and "just from personal experience" it's very possible to use an NVD and glass eyepieces on a single scope (indeed on many commercial scopes that's just a nothingburger; e.g. on a Skywatcher you just remove or add the 45 mm 2" extension tube they supply for using with 2" glass eyepieces).
Perhaps not if you tune a self-built scope to the bone for glass eyepieces, a specific type of coma corrector (the Paracorr Type2, aka P2) and an aggressively maximized fully illuminated field. In that case you might indeed paint yourself in a corner where only a P2 will work or you'll have to accept compromises (like having a filter slide or even a coma corrector slightly in the light path, not using a filter slide when you use a Nexus, or moving the focal plane slightly out temporarily with other trusses or different main mirror collimation adjustments, at the expense of a slightly smaller fully illuminated field...the list is long). But then, using a P2 is in itself a sort of compromise (given its 1.15x barlow factor has side effects not everyone wants all the time).
But many of us are willing to live with such compromises when necessary, and compromises are not "problems".
Anyone using a commercial scope doesn't even have to compromise, the manufacturer will often have made compromises to maximize flexibility at the expense of an aggressive but one-sided optimisation that some others might have preferred.
I'll reiterate: I think pointing out what can be important to check and is relevant to the original poster's question (will my scope work with a Nexus? Does it need the lip removed? Will it conflict with my filter slide if I have one and the lip was removed? How much will the Nexus intrude in the light path?) are fair and on-topic. And your posts that helped answer those are still in the thread.
Discussions about which scope designs or coma correctors are "correct" and which are "wrong" or "a problem" are not (though the design criteria are regularly discussed, but on the ATM forum).
And we should not go around saying problems "are likely" without enough context, certainly given there are no problems on the vast majority of scopes that I've seen; I tried a stopless Nexus+NVD at a star party on more than ten scopes last weekend, unusable on zero scopes -- I confess I am not counting the scopes with a 1.25" focuser ;-).
A Nexus indeed has the
potential for introducing issues because of a telescope end that protrudes into the tube/UTA that a Sharpstar/Maxfield won't, and that one has the
potential to introduce an issue that a P2 won't.
But if there are no problems, it's not "more problems than a Sharpstar", because 0 > 0 is a false statement.
Edited by sixela, 17 March 2024 - 06:32 PM.
