Hi Wayne,
I'm surprised to hear of an event like this with a LX850. Not to say motors don't fail, but it's FAR more often motor driver chips, encoders and interconnections that cause issues.
1st off,
Andrew is as good as it gets on Meade gear.
Meademods is relatively close geographically and that's good news if you need direct assistance, and of course there's Meade support. Hope you will hear soon. Meade might be able to supply specific tech data if you ask the right questions on motor windings resistance, etc. I haven't interacted with them lately.
Thinking about what I might add to the discussion, and few things I'd suggest checking at this point.
Your nose smelt an overheating. But the important unanswered question is not only WHAT but also WHY.
* is the motor actually frozen now that you've got it out?
* check and record motor windings resistance, opens, shorts.
* check windings for shorts to motor frame/case.
At this point you'd be looking to see if the windings are intact, have actually burnt out or a short exists, but the actual readings might be a useful reference for future use.
The motor driver board status is a big ?? in my mind, especially if it's pushed enough current to burn or overheat a motor winding and in fact could be the root cause of a damaged motor.
* Have you reconnected the motor since removal to see if the driver will move it during scope initialization ?
If the DEC axis motion was frozen in a power off condition and is now free with the motor removed I would speculate that the LX850 motor has integral gear reduction and that's where the failure occurred. It might not be immediately apparent under no load stand alone testing. I'd give it a try as it might be illuminating.
What was the status of the OTA and associated optical gear at the time of failure?
What was the DEC balance like? Nose or mirror heavy? Position? In retrospect were there any prior symptoms?
Before ordering and putting expensive and hard to obtain replacement parts in place, it's important to understand everything we can about what failed, how it failed. and to the extent possible what caused the failure. So too, also inspect and test as many of the involved component parts as we can in the process both to rule out root causes and to identify any collateral damages.
I'd be hesitant to wholesale replace the entire DEC assembly. Seems to me that a very expensive sledgehammer is the wrong tool at this point. I would not contemplate anything as drastic, as you put it, a mount replacement due to the cost of a motor.
Just as a point of reference and context for myself and others, as I haven't seen or heard much about LX850 hardware issues, and if you don't mind sharing, might I ask:
How old is the scope? Can you estimate how much operational time is on it? It's sufficient to say even in broad category; ie. occasionally, X times/month, weekly, daily.
Is it permanently mounted (observatory,etc) or portable use. If portable, is it set up and taken down each time or left set up on a tripod with wheels, etc.
I'm just trying to get an idea of circumstances in general to gain better insights and a knowledge record from your unfortunate incident and situation.
There is a great community here, ready and willing to help you work through this best we can. Every bit of info recorded in posts here will likely help others at some point.
Michael
