The old supernova remnant SNR G179.0+2.6 in the constellation Auriga is dominated by OIII emissions. They form a mixture of diffuse and filamentary structures that together form a round closed shell with a diameter of about 70 arcmin.
The Ha emission significantly less pronounced and more diffuse in the form of a horseshoe-shaped, i.e. non closed ring.
The image data was shot with four different telescopes ( 2 x TS 130/910 mm triplet apo @ 740 mm, 1 x TS CF-Apo 80 @ 480 mm, 1 x TS 80/480 mm triplet apo @ 480 mm). The image shows the 480 mm frame. The cameras were 4 ZWO ASI2600mm pro.
Because the skies here in my place were very unfriendly the last months I was very happy that my collaboration partner fom the M!06 propject Philip @pmneo supported me with additional data from his site in Bavaria!
In total about 61 hours of data were used for the image integration:
409 x 300 s Ha
327 x 300 s OIII
Full Version: https://astrob.in/full/sncfdf/0/
Cheers
Pete
Data:
Celestial hemisphere: Northern ·
Constellation: Auriga (Aur) · Contains: PGC 101339 · PGC 135910 · PGC 168999 · PGC 169006 · PGC 169007 · PGC 169011 · PGC 169012 · PGC 169013 · PGC 169015 · PGC 169016 · PGC 169017 · PGC 169020 · PGC 169021 · PGC 169023 · PGC 169026 · PGC
169028 · PGC 169033 · PGC 17870 · PGC 17876 · PGC 1948363 · PGC 3097800 · PGC 3098001 · PGC 97122 · PGC 97140 · PGC 97466
TS-Optics CF-APO 80mm f/6 (TSCFAPO80) × · TS-Optics Photoline 130mm f/7 FPL53 Triplet Apo (APO130f7-P) × · TS-Optics Photoline 80mm f/6 (TLAPO804) ×
Imaging Cameras ZWO ASI2600MM Pro
Mounts Sky-Watcher EQ6-R Pro · Sky-Watcher EQ8-R
Filters Antlia O-III Pro Ultra Filter - 2.8 nm Ultra Narrowband - 36 mm · Astronomik H-alpha CCD 6nm · Astronomik OIII CCD 6nm 36 mm · Chroma OIII 3nm Bandpass
Accessories Lacerta MFOC Motorfocus · Pegasus Astro Falcon Rotator · TS-Optics Photoline 3" 0.79x ED Reducer/Corrector (TSRED379) × · TS-Optics TSFlat2.5 × · ZWO EFW 7 x 36mm
Software Adobe Photoshop · Aries Productions Astro Pixel Processor (APP) · Pleiades Astrophoto PixInsight · Stefan Berg Nighttime Imaging 'N' Astronomy (N.I.N.A. / NINA)
Antlia O-III Pro Ultra Filter - 2.8 nm Ultra Narrowband - 36 mm: 108×300″(9h)
Astronomik H-alpha CCD 6nm: 409×300″(34h 5′)
Astronomik OIII CCD 6nm 36 mm: 99×300″(8h 15′)
Chroma OIII 3nm Bandpass: 120×300″(10h)
Integration: 61h 20′
RA center: 05h53m44s.14
DEC center: +31°09′47″.7
Pixel scale: 1.593 arcsec/pixel
Orientation: 0.218 degrees
Field radius: 1.519 degrees
