What about in terms of seeing more challenging objects? I'm in Bortle 9 so NV opens up a lot of impossible objects with glass only. Would the SmartEye go even further because it stacks? That is, could we potentially see things that not even PVS-14 NV would allow?
You can get stacking with NV if you use something like Astroshader on an iPhone, You do need tracking for that (but you'd need that for any stacking). There are some lovely examples of stacked NV images on the NV forum.
Galaxies are not a great target for NV (I think). The SE with a longer FL OTA would likely show more details. Correct me if I'm wrong on this...
No I think NV also does excellent things with galaxies - the NV forum has some good examples.
I have an NV and have been thinking about the SE, but I'm coming out on the side of passing on this version of the SE:
1. NV can give instant viewing, and tracking - SE only with tracking.
2. NV can be used 1x, 3x 5x etc - SE only with a scope.
3. NV doesn't do colour, but to me that's not enough of an advantage to justify an SE (monochrome viewing of objects can be beautiful to see the structure - and most of the time for nebulae you're going to see red for HA anyway!)
Having said that, if there was a version of the SE with (a) less coma in the EP (is 90 degree really needed - I'm quite happy with a Nagler's 82 degrees - would an 82 degree SE have significantly less coma?) and (b) a larger (APS-C or 4:3) sensor that could justify being used as an imaging camera backup (a 533 sensor is too small in FOV especially with wider field scopes), then I'd reconsider.
I should also caveat that for EAA I have a Dwarf 3 which tbh is remarkable - no mount needed and much cheaper.
Having said that, full kudos to Pegasus for having pioneered this. I'm looking fwd to future iterations.
