I was toying with the site ssd.jpl.nasa.gov/horizons/app.html#/ again and in a spreadsheet I made a chart for angular size cycles for Jupiter, Mars and Saturn rings in the years 2023-2075. Each cycle is represented by 3 parts: opposition + two solar elongations of 60 degrees.
By opposition I mean the biggest solar elongation in each cycle (on the NASA site the solar elongation never reaches 180 degrees – it's probably calculated for 3 dimensions, not just 2).
I calculated each size of the Saturn rings as 2.2x angular size of the plain Saturn. The rings are actually slightly bigger than this, but I didn't want to overstate them.
The results are quite interesting (click to enlarge):
Here's a chart only for the years 2023-2036, so it's easier to see some details:
The charts confirm my (short) personal experience and what I've read on the net (including this forum) about observing planets in the long run, but there are also some surprising cases:
1. Mars is usually very small and disappointing. Oppositions are rare. The best oppositions are very rare.
2. Jupiter is clearly the best when close to opposition. When it's far from opposition the Saturn rings are often bigger.
3. Saturn, as far as the rings are concerned, is always “good enough”, even far from opposition. The best oppositions are very rare, but they are not all that different from average oppositions.
4. In some years (most notably in 2064) the size of Jupiter at opposition is smaller than the size of Saturn rings at Saturn opposition.
If anybody is interested, below there are screenshots how I gathered the needed data. I chose a location as close to my location as possible, but it's not really important as far as angular sizes of planets are concerned.
In order to identify oppositions and solar elongations of 60 degrees and then to combine the results into one chart I had to come up with some specific spreadsheet formulas, but to me it was fun.
Clear skies!
Edited by Marcin_78, 30 March 2024 - 08:13 AM.
