Hi all,
I am working to automate my setup and ran into a frustrating situation. I have successfully tested my camera with EO and was going to by the pro software to build fully featured scripts but they have started a sales blackout. They won't sell it for the week leading up to the event! I emailed them requesting an opportunity to purchase, but I'm guessing they're on vacation for their own eclipse photography.
I'm struggling to manually create a script to capture the phenomena not available in the free version and could use a starting point which features all of the phenomena from the script wizard.
If someone would be so kind as to create a script with all the phenomena with my setup info I can fiddle with it from there. I will greatly appreciate being bailed out here!
I'll be shooting from Waco TX area without a shutter release cable using a D850 and a 500mm focal length. Details below. I don't have a tracker and without mirror up lock I expect a lot of shutter shock so I'm trying to opt for the fastest shutter speed possible.
Location (not necessary for script?)
31° 26.3050' N
97° 42.6283' W
Elevatoin 130 m
Maximum Exposure Time:2 second
Prefferred Aperature: 5.6
Preferred ISO: 400
File Type: RAW
Minimum Spacing between exposures: 1 Second
Please select all phenomena
Camera is
500 mm, .5.6 f/
Recyle time .75s
No shutter cable (haven't figured how to do this on D850)
No mirror lock up (Unavailable w/o shutter?)
I greatly appreciate anyone who can help!
Here you go. I had to use my camera as I don't know which one you have. Also, the script loaded an fratio of 5.0 instead of 5.6. I used a value of 1 for all set values. You'll have to adjust the timing and shutter speeds accordingly - nothing a good hacker can't overcome.
Now, having brought up the hacker subject, does ANYONE know where I/we can get a "Script/programmers" manual for this command set???? I can't believe this thing has been out for nearly 30 years and nowhere, does an internet search for information on the various command fields return useful, detailed information - My thanks in advance for an accurate answer.
FOR,(INTERVALOMETER),0,1.000,1
TAKEPIC,C1,-,00:01:00.0,T6S-80mm,1/4000,5.0,400,0.000,RAW,,N,Uneclipsed Sun pre-eclipse, filter on
ENDFOR
FOR,(INTERVALOMETER),1,1.000,1
TAKEPIC,C4,+,00:01:00.0,T6S-80mm,1/4000,5.0,400,0.000,RAW,,N,Uneclipsed Sun post-eclipse, filter on
ENDFOR
TAKEPIC,C1,-,00:00:00.0,T6S-80mm,1/4000,5.0,400,0.000,RAW,,N,First contact, filter on
ENDFOR
TAKEPIC,C4,+,00:00:00.0,T6S-80mm,1/4000,5.0,400,0.000,RAW,,N,Fourth contact, filter on
ENDFOR
FOR,(VAR),1.000,1.000,99.900
TAKEPIC,MAGPRE (VAR),+,00:00:00.0,T6S-80mm,1/4000,5.0,400,0.000,RAW,,N,Partials C1-C2, filter on
ENDFOR
TAKEPIC,MAGPOST (VAR),+,00:00:00.0,T6S-80mm,1/4000,5.0,400,0.000,RAW,,N,Partials C3-C4, filter on
ENDFOR
PLAY,C2,-,00:10:00.0,Sounds/10minutes.wav,,,,,,,,"10 minutes" voice prompt
PLAY,C2,-,00:05:00.0,Sounds/5minutes.wav,,,,,,,,"5 minutes" voice prompt
PLAY,C2,-,00:02:00.0,Sounds/2minutes.wav,,,,,,,,"2 minutes" voice prompt
PLAY,C2,-,00:01:00.0,Sounds/60seconds.wav,,,,,,,,"60 seconds" voice prompt
PLAY,C2,-,00:00:30.0,Sounds/30seconds.wav,,,,,,,,"30 seconds" voice prompt
PLAY,C2,-,00:00:20.0,Sounds/filters_off.wav,,,,,,,,"Filters off" voice prompt
PLAY,C2,-,00:00:10.0,Sounds/10seconds.wav,,,,,,,,"10 seconds" voice prompt
PLAY,C3,+,00:00:20.0,Sounds/filters_on.wav,,,,,,,,"Filters on" voice prompt
TAKEPIC,C2,-,00:00:01.0,T6S-80mm,1/4000,5.0,400,0.000,RAW,,N,Baily's Beads C2
ENDFOR
TAKEPIC,C3,+,00:00:01.0,T6S-80mm,1/4000,5.0,400,0.000,RAW,,N,Baily's Beads C3
ENDFOR
TAKEPIC,C2,-,00:00:02.0,T6S-80mm,1/500,5.0,400,0.000,RAW,,N,Diamond Ring C2
ENDFOR
TAKEPIC,C3,+,00:00:02.0,T6S-80mm,1/500,5.0,400,0.000,RAW,,N,Diamond Ring C3
ENDFOR
TAKEPIC,C2,+,00:00:01.0,T6S-80mm,1/4000,5.0,400,0.000,RAW,,N,Chromosphere C2
ENDFOR
TAKEPIC,C3,-,00:00:01.0,T6S-80mm,1/4000,5.0,400,0.000,RAW,,N,Chromosphere C3
ENDFOR
TAKEPIC,C2,+,00:00:02.0,T6S-80mm,1/4000,5.0,400,0.000,RAW,,N,Prominences C2
ENDFOR
TAKEPIC,C3,-,00:00:02.0,T6S-80mm,1/4000,5.0,400,0.000,RAW,,N,Prominences C3
ENDFOR
TAKEPIC,MAX,-,00:00:06.0,T6S-80mm,1/2000,5.0,400,0.000,RAW,,N,Corona bracketing 0.1 Rs
TAKEPIC,LAST,+,00:00:01.0,T6S-80mm,1/1000,5.0,400,0.000,RAW,,Y,Corona bracketing 0.1 Rs
TAKEPIC,LAST,+,00:00:01.0,T6S-80mm,1/500,5.0,400,0.000,RAW,,Y,Corona bracketing 0.2 Rs
TAKEPIC,LAST,+,00:00:01.0,T6S-80mm,1/250,5.0,400,0.000,RAW,,Y,Corona bracketing 0.2 Rs
TAKEPIC,LAST,+,00:00:01.0,T6S-80mm,1/125,5.0,400,0.000,RAW,,Y,Corona bracketing 0.5 Rs
TAKEPIC,LAST,+,00:00:01.0,T6S-80mm,1/60,5.0,400,0.000,RAW,,Y,Corona bracketing 0.5 Rs
TAKEPIC,LAST,+,00:00:01.0,T6S-80mm,1/30,5.0,400,0.000,RAW,,Y,Corona bracketing 1.0 Rs
TAKEPIC,LAST,+,00:00:01.0,T6S-80mm,1/15,5.0,400,0.000,RAW,,Y,Corona bracketing 2.0 Rs
TAKEPIC,LAST,+,00:00:01.1,T6S-80mm,1/8,5.0,400,0.000,RAW,,Y,Corona bracketing 4.0 Rs
TAKEPIC,LAST,+,00:00:01.1,T6S-80mm,1/4,5.0,400,0.000,RAW,,Y,Corona bracketing 4.0 Rs
TAKEPIC,LAST,+,00:00:01.3,T6S-80mm,0.5,5.0,400,0.000,RAW,,Y,Corona bracketing 8.0 Rs
TAKEPIC,LAST,+,00:00:01.5,T6S-80mm,1,5.0,400,0.000,RAW,,Y,Corona bracketing deep
FOR,(INTERVALOMETER),1,2.000,1
TAKEPIC,MAX,-,00:00:08.0,T6S-80mm,1,5.0,400,0.000,RAW,,N,Earthshine/stars
ENDFOR
