Looking for a solution to “trick” the software into save a “custom” park position ( OTA horizontal) other than “home” ( weights down looking at NCP). Tried several things with both EQMOD and GSS, either gets “lost” and would not sync to a position if encoders were not sync to a home/park position pointing at the NCP.
I don’t understand why software gets confused, home/park being two very different things. I tried to sync encoders to a “horizontal” park position then sync “home” to a “weights down / point to NCP” position, in either case the mount got lost and would yield the usual “coordinates out of sync limits” error when I try to solve/sync a position in the sky.
Most likely I’m doing it wrong, appreciate if someone can point me in the right direction.
Just moved my scope to a more permanent location inside a low profile shed that needs the scope horizontal so the roof can be closed. I would like to be able to define a horizontal park position to avoid having to slew it manually at the end of each session ( and eventually be able to automate the roll off roof to close at the end of a session after parking the mount)…
Edited by Intihuatana, 03 April 2024 - 10:32 AM.
