Well you guys are giving me a whole bunch of informations here. I'm considering all your inputs, let me go deeper for a moment;
I'm into binoculars mainly because I prefer the binocular view, it's more relaxing, it give me more details and a higher level of immersion.
Problem is, with my actual photo tripod i barely can hold still my 2.5kg 15x70, so I figured out that I need a more sturdy mount, in case I get a 20/25x bino or even more one of those with interchangeable oculars, which goes up to 4kgs and more.
Furthermore, it's not a stability issue only, when you approach those mag levels above 20x the FOV is considerably small and you benefit from a micrometric (or at least a very, very precise one) head that let you move into your scene smoothly.
A pretty cheap AZ mount checks all the marks, is sturdy enough and allows you to move precisely on 2 axis, which I think would be a real benefit for long distance observation both in night and daytime.
My initial question was mainly about the convenience of having a single mount to carry around, but you raised some solid points here (the ergonomic disadvantage of a straight big bino mounted like a telescope is a strong point and I'm considering it).
In the meantime, I'm scanning the market and found some AZ mounts that would work well with a telescope only i think, main reason is the dovetail plate is placed sideways respect the optical tube which is common for telescopes but not for usually below-mounted binos (proper L brackets to fix this could exist but I'm unaware of it). An example, the aforementioned Twilight I AZ mount.
I've also found mounts that will fit better, like the Skytee 2, which I think could hold both a telescope and a bino simultaneously, having 2 plates.
Still, the separate bino and telescope mount is a good advice and maybe more modular.
A final word on EQ; currently I'm not into astrophotography so much that I need an accurate tracking for stacking very long exposures. I also think that for that kind of stuff it probably would be advisable to get a good motorized mount.
Let me thank you again for your help, btw.
And please forgive my bad english
V
Edited by chenesis, 06 April 2024 - 06:28 AM.
