LX200GPS-cant find target
59 replies to this topic
#51 pgtuck
pgtuck
Posted 23 April 2024 - 07:10 PM
these pics didn't come through. These poped up as the data download started. I cleared each one to continue
#52 pgtuck
pgtuck
Posted 23 April 2024 - 07:17 PM
#53 pgtuck
pgtuck
Posted 23 April 2024 - 07:34 PM
New data dump.png new data download with time locn from setup status tab
#54 OzAndrewJ
OzAndrewJ
Posted 23 April 2024 - 07:49 PM
Gday pgtuck
The warnings re PEC are because the old stored PEC model never got changed
to the new PEC formats in 4.2G
Just go to the "Setup > Telescope > Smart Drive" menu
Under that select RA PEC and do a factory reset
then select DEC PEC and do a factory reset.
That wil rebuild the file data properly and my app will stop complaining
More re your data shortly
  • Skywatchr likes this
#55 OzAndrewJ
OzAndrewJ
Posted 23 April 2024 - 08:08 PM
Gday pgtuck
OK, the data you got does not appear to be fresh after a boot
ie there is a big difference between LST1 and LST2, and that cant ( Normally ) happen
unless you have done an align and got a big error, or manually editied something
What i need is
turn off the scope
turn it on and let it fix
As soon as if fixes, and before doing anything else,
connect my app and run the Time/Locn test
Post the results
This will tell us exacly what status it is in on booting.
Edited by OzAndrewJ, 23 April 2024 - 08:12 PM.
#56 pgtuck
pgtuck
Posted 23 April 2024 - 08:15 PM
New data with smart drive on. hand set data now matches scope data.
#57 pgtuck
pgtuck
Posted 23 April 2024 - 08:49 PM
Adding setup data after turning on smart drive. No manual corrections to anyting
#58 OzAndrewJ
OzAndrewJ
Posted 23 April 2024 - 11:08 PM
gday pgtuck
OK, you can turn the Smart drive OFF if you want as its not needed
All you needed to do was rebuild it to suit the changed data structure
and my app wont complain :-).
In the first screengrab, ( just after getting a fix ),
you see top centre the  lable "GPS data valid"
This worked as the GPS was on and had fixed.
The second grab has wrong data from the GPS and the lable
says "GPS data may be suspect"
This is because you ran the update 30mins later and as such the
GPS had shut down, and needed a cold start.
That said, the last plot shows the correct local date time and UTC
and both LST1 and LST2 are identical, ie it got set properly
They normally only every desynchronise if you have a really bad align
or something plays with the system date after booting.
Soooo, just on a hunch, do you ever connect to it using NINA
( or any other app ) after getting a fix????
#59 pgtuck
pgtuck
Posted 24 April 2024 - 08:49 AM
I only use the autostar 2 hand controller or, occasionally scope boss wifi connection.
Thanks again for all of your Help. It was a learning experience!
#60 pgtuck
pgtuck
Posted 24 April 2024 - 09:42 PM
Andrew and. Dave. Thanks for your incredible help!
