I wonder if there is any kind soul out there who could help me with a vexing problem regarding my Meade Autostar II handcontroller which I use with my Meade 30 cm LX200 from 2007.
The problem I have is that that the telescope doesn't slew to the target object when I press the GOTO button; I just get information about when the object rises, sets etc.
I suspected a problem with a worn out GOTO button and so I ordered a brand new handcontroller, identical to my previous controller but the problem repeats itself.
There don't appear to be any mechanical or power problems with the telescope. Autostar II goes through its alignment procedure perfectly and the manual slewing is fine with the arrow buttons.
Upon successful alignment, I check the alignment by slewing to a couple of named first magnitude stars which works fine. The problems start when I try to slew to other objects. There is a slight humming sound consistent with the lowest slew speed (x8 or guide) when I press the GOTO button but otherwise nothing happens. Could it be that the telescope reverts from the max slew default speed to guide speed following the first couple of initial slews?
Has anyone experienced a similar problem? How can I solve it?
Thanks in advance for any suggestions
Chris Allen / Sweden
