The shadow technique for point my scope doesn't work in overcast skies - UGH
2 replies to this topic
#1 dcaponeii
dcaponeii
  • Loc: Waxahachie, TX
Posted 08 April 2024 - 10:38 AM
Waxahachie is still in bad shape.  GOES loop looks like it's trying to burn off some but still unsuitable for viewing.  Finger's crossed.
#2 quantumgiggles
quantumgiggles
Posted 08 April 2024 - 11:03 AM
Another technique is to put on your eclipse glasses and line up the barrel of the scope with the Sun. It's not as quick as the shadow method but within 5 minutes you can get it
#3 dcaponeii
dcaponeii
Posted 09 April 2024 - 04:58 AM
Or, do what I did and wait an hour for a hole in the clouds. Before then there wasn’t much to site down the barrel to find. Note: other readers should realize that the Sun in even a moderate cloud layer becomes invisible with eclipse glasses. A clearly visible Sun behind a layer is simply not visible with your glasses on. If you can see the Sun with glasses then it’s casting a sufficient shadow to work with.
