I used PIPP (planetary imaging pre processor) to register 2,520 still frames to make my 2 hr 51 min timelapse:
https://youtu.be/ABtjGDFer7A
I did it in 3 batches and made a separate avi file for each partial phase and one for totality. Once I made an avi file for each of the 3 separate phases, I then stitched each of the individual avi files together using OpenShot Video Editor.
Once you've loaded your frames in PIPP, click on the "processing options" tab, employ object/planetary frame stabilization and center the object in each frame. For the partial phases, use the "edge in shadow" feature and select the appropriate edge from the dropdown menu. There are many other settings that you can fiddle with as well, including histogram adjustments, debayering raw frames, output video fps and compression options, etc.
Hopefully this will get you started. Let me know if you need any more details.
Matt
It's a great video, thanks for sharing.
No offense to your great work and timelapse, but the software did a terrible job at alignment - its all over the place. If it was me and had the great data you had, I would definitely redo the entire thing but manually align instead. Your great captures deserve better and the bouncing around takes away from your timelapse.
Unfortunately, I think the only way to really do this well is manually in photoshop.
This is what I did.
1. Use script and load stack of a bunch of images. I've done 50 at a time.
2. Use a single (and the same) image as a reference image
3. Set blend mode to difference for all the frames except reference.
4. Then one at a time, align the frame manually.
This works extremely well, and once you do it, it can be done VERY FAST. I can do 50 frames in about 5 minutes.
