How did you get PIPP to align without moving the crescent? I can’t get PIPP to align the edges to keep everything in one place.
First I loaded the source files, keeping the images from each phase of the eclipse separate from those from the other phases. I processed the initial partial phase images first, then the totality images, then the final partial phase images last. For each batch I selected to optimize for solar/lunar full disk using join mode on the Source Files tab.
Here's a screenshot of the settings that I used on the Input Options tab. My files were rgb24 files so essentially I just left everything unchecked.
Here's a screenshot of the settings that I used on the Processing Options tab. The stretch histogram white point to 95% setting compensated for the frames that were dimmed by the passing of thin clouds during the partial phases. I had to test a few different settings for the minimum object size and object detection threshold options before I found a combination that worked well. The size of my raw frames is 4144 px x 2822 px so the cropping settings ensured that the frames remained their original size.
I disabled the quality estimation feature on the Quality Options tab. I then saved the output as a raw, uncompressed avi file at 30 fps.
