Here's a copy of a reply I just posted in another thread that was also asking about timelapses.
I used PIPP (planetary imaging pre processor) to register 2,520 still frames to make my 2 hr 51 min timelapse:
https://youtu.be/ABtjGDFer7A
I did it in 3 batches and made a separate avi file for each partial phase and one for totality. Once I made an avi file for each of the 3 separate phases, I then stitched each of the individual avi files together using OpenShot Video Editor.
Once you've loaded your frames in PIPP, click on the "processing options" tab, employ object/planetary frame stabilization and center the object in each frame. For the partial phases, use the "edge in shadow" feature and select the appropriate edge from the dropdown menu. There are many other settings that you can fiddle with as well, including histogram adjustments, debayering raw frames, output video fps and compression options, etc.
Hopefully this will get you started. Let me know if you need any more details.
Matt
