Image Blur When Stacking Partial Solar Eclipse SERs
3 replies to this topic
#1 AZJohnnyC
AZJohnnyC
  • Loc: Phoenix, AZ
Posted 12 April 2024 - 01:34 PM
Hi all,
I'm wrestling with image blur when stacking partial solar eclipse SERs.  With all the setting variations I've tried in Autostakkert!4, the surface of the sun keeps blurring where it's crossed by the limb of the moon.
Does anyone here know of a method (perhaps not including Autostakkert!) that will allow me to process my SERs into stacked TIFS without blurring?  I'm open to any reasonable suggestions.
Thanks in advance,
John
#2 MalVeauX
MalVeauX
  • Loc: Florida
Posted 12 April 2024 - 01:36 PM
Can you share examples?
Have you looked through your entire SER container to see if it's because of wind or shake or dark/lines in the frames periodically?
Very best,
#3 dcaponeii
dcaponeii
  • Loc: Waxahachie, TX
Posted 13 April 2024 - 10:37 AM
My best advice is to try the expand function to break your ser into smaller amount of frames. For example my 12” capture video was 3400 frames but I used expand set to 150 and 150 to generate individual stacks. If you want more with some overlap then set for example 150 and 75 and the start of the new stack will be at the center of the previous one. Just toss the ones that don’t look good. Also you can split the entire ser into individual frames with PIPP and then drag and drop specific groups of frames into AS!4. That was my only solution near the start and end of totality.
  • AZJohnnyC likes this
#4 AZJohnnyC
AZJohnnyC
  • Loc: Phoenix, AZ
Posted 17 April 2024 - 08:47 AM
Thanks so much, dcaponeii! That makes a lot of sense. I appreciate your suggestions!
- John
