Just came back inside from comparing my 4.5, 6.5, 9mm Morpheus, 5mm Delite and 3.5mm Pentax XW on the moon. Using the 130mm F/5 newt.
The 6.5 and 9 Morpheus felt like an extension of the excellent 12.5 and 17.5. The 4.5, however, seems to be a different animal. It's not as comfortable to use as the rest of the line. Eye placement is more difficult, I get kidney beaning, and it also has obvious EFOB compared to the other Morpheus and also the Delite and XW. All the Morpheus had significantly more scatter than either the Delite and XW when moving the moon just outside the FOV, and even when a part of the moon is in the FOV, there is scatter present which was distracting. Where the 6.5 and 9 differ though is the comfort, they just "fit" my eye, I could hold the exit pupil, and there was no EFOB or kidney beaning. They feel like a natural extension to the 12.5 and 17.5, whereas the 4.5 is something else entirely.
The Delite and XW have much better scatter control. The XW had just the most minimal glow as the moon was moved outside the FOV. The Delite had essentially none. Like the 6.5 and 9 Morpheus, I found both the Delite and XW much more comfortable than the 4.5 Morpheus once I got the eyecup dialed in. All eyepieces had the green and blue fringing when moving the lunar limb to the edge of the FOV.
That being said, the 4.5 Morpheus IS sharp and has a nice neutral tone. The colours were pure and crisp. Shadows nice and black. Good resolution of tiny features. The Delite I feel is still a tad more crisp, but, the difference really is small.
Even if you've never used a particular eyepiece before, the first time you use it, you just "know" if it's going to be a keeper or not. I did not get that same feeling from the 4.5 Morpheus as I did from the others. I would like to try a Delos...
Edited by HellsKitchen, 20 May 2025 - 04:17 PM.
