I'm trying to fix a broken mirror float system under a 14.5" mirror on a Sky Designs truss Dobsonian.
I need to remove the mirror to get to it. In theory, I could lift the mirror up and out, but the hole in the top is just slightly larger than the mirror diameter (about 0.25 inches).
It seems more logical to remove the top shell of the box, so I removed the lower ring of screws, but that bottom platform won't fall out (gently of course).
I have to be careful because I don't know what is poking the back of the mirror.
I've tried to gently nudge it with a rubber mallet. Pry it with screw driver. I don't see any more screws.
Note: This doesn't have the sling mount, but has four nylon bolts that center it and four wood hold-down tabs.
On the left side (the side with a trunion) is a stack of what looks like linoleum pieces. They are about 0.5 inches away from the mirror.
Does anybody know or remember what the standard method was for removing the mirror? I'd like to avoid laying the box on the side and manhandling it out.
Note: when I get it out, I'd like to add hinges and a couple of lock bolts.
John
