I've used AutoStakkert! before for similar images (many times, and here is a post on CN from 2017), but I'm not sure it will work that well with such a dim and ill defined image give the base exposure that I used. It should work given a longer exposure, but then the moon will have a greater amount of blur from the seeing and the errors in tracking. In any case I still want to try a variety of stacking methods to see which one works best and AutoStakkert! is on the list for such work. I also need to see whether it will stack better in a RAW, linear format or if it would be better to start with a non-linear, stretched image. The latter might be better for Autostakkert! or some of the other techniques that I may try. Photoshop produces a really good looking result with its RAW processing and its RAW denoising option may be the best I've ever used (although it is very slow, it would probably take two hours for it to finish all of my subs given that each is 46 megapixels in size).
For this first round I also wanted to do all of the processing on my Macbook Air and I've never tried to run AutoStakkert! on a Mac using some kind of emulator for a Windows PC.
Interestingly enough, the sequences where I used a normal exposure for the sunlit side of the moon also show some traces of the earthlit side and while I've done images before that revealed feature on both sides they've never been to my complete satisfaction. But, this is the first time I've used the Nikon Z8 on the EdgeHD so this configuration may provide some advantages over what I've done before.
As is, this is still a pretty sharp image (IMO) and the question would be whether it can be made any better with a different alignment method.
Yes, flats should work to even out the background, but the vignetting was so severe that I couldn't even record stars in those areas (i.e. the corners had near zero exposure). Also, the camera has already been removed so it's probably too late to get any quality flats and one issue that I had not yet mentioned is that these same areas that begin to show vignetting also show flare and ghosting from the grossly overexposed moon. What all of this means is that I couldn't use the entire frame from the Z8, but little if any of that affected the moon but it would have been better to have had a clean, full-frame result.
Edited by james7ca, 15 April 2024 - 05:38 PM.
