So I tried best I could to follow a quick step by step I found on using PI. I've be able to make a pretty good effort I think at reprocessing the data.
I do have a few quick questions. First this is roughly a little over 6 hours of data. Would it benefit any to go to 10 hours? Secondly and this probably won’t be easy to explain to a newbie lol. How are yall getting the data to come out looking sharper and cleaner than I’m doing? I’ve been playing with PI and couldn’t get color and had to go back into photoshop to get color, but I can’t seem to get the final product to come out as sharp looking.
Your second effort is really great! The only thing additional I might suggest is SCNR as it looks a little bit green to me. Keep practicing. One thing I've found helpful is to leave the image for a day, then come back and see how you like it. I'm almost never done processing and I still have data from a year ago I go back and re-process. It's quite amazing what a difference a year of experience will do for you.
I think the hardest part of learning processing for me was getting over the fact that there is no formula. You won't always run SCNR at 100%, or you're not trying to target a stretch value of "5.3," for example. Each image will be different. The noise characteristics may take a different tool, HDR composition will not always work well, sometimes masking doesn't really help. What really helped me when I started this so many years ago was understanding what the transformations are doing to the underlying data. I think that's why Pixinsight is more natural for me. It's really all just mathematical transformations and manipulations, you just have to apply it to the right part of the data, so knowing that helps build a picture of where you want to go. In your picture, there was some background noise I wanted to suppress and this required a funky curve application to prevent losing the tidal tails. Once you know right where a certain part of the data lives in the image, you can bend it to your will.
As for sharpening, I'd echo the above. BlurXterminator and LocalHistogramEqualization help with this as well as careful Unsharp Mask application. There are a couple of image blend scripts now, so I can over sharpen one image and over stretch a clone then combine to get a good blend of detail in the shadows and midtones. I also think that some of what you perceive as sharpness may actually be contrast. When you define the line between different regions, it tends to make them "pop" and the definition of the regions is more appealing.
Keep it up! You've already come a long way. Set a general workflow, then play with the settings within that workflow.
Have you downloaded any process icons? That made things a bit easier for me. Pixinsight contains a lot of bloat anymore with obsolete or rarely used tools. It can be hard to navigate and know what is best to use.
Edited by Kerry D. Green, 15 April 2024 - 08:19 AM.
