I'm trying to adapt ZWO ASI1600MC-C to a Celestron 8SE SLT.
I was able to use a 2" diagonal but I'd rather just go straight back (and also inline a filter wheel eventually).
The Celestron 8SE scope has a threaded back. Ideally I'd thread straight to the ZWO ASI1600, but also just getting a 2in "eyepiece" type adapter straight back might be good enough (and maybe make it easier to rotate/orient the camera).
There was a shop in Florida that used to make such adapters (I mean you'd select the components and they "made to order" the adapter, but you may have to experiment on the depth), not sure if they are still around.
