So it happened. I blame the lunar eclipse , initially I was drawn to solar but with no Herschel wedges in stock almost anywhere and with the solar scopes going for the likes of a decent second hand car , I've got a binoviewer.
Leica microscope head they say , with mirrors they say , it's gonna be fun they say , beware the backfocus they say...Of course , like all good advices you think about what "they say" after the deed is done
Well, at least a pair of EP's was included in the deal , and I'll admit the combo is banging, I just saw the Moon in what I can only describe as 3D.The colleague that I bought them from told me they are from an older Zeiss 8x30 Deltrintem. They each have a plastic sleeve that makes it a perfect fit in the D30mm receptacles. The nosepiece is a 2" with internal M48 thread that I intend to use for a GPC of sorts.
The BV does focus with my TS APO's in straight through view with some 15mm remaining on the focuser. Both the 80mm and the 102mm have the same 2.5" focuser and same 123 mm from 2" receptacle / 161 mm from M63 thread backfocus so I guess the optical length of the binoviewers is some 108mm (123mm-15mm remaining on the tube) so the fight is on for some 40 mm I guess ( advices welcomed)
Also , it seems I have to learn a bit about microscope EP's equivalation to the "normal" telescope EP's focal lengths and a couple of manufacturers from that domain.
