Understood, so I should set my sub exposure to where the mean ADU is around 2890 according to this in order to be properly exposed? thank you again for your help on this. Sometimes I just need it to be explained like I am 5 lol.
By “properly exposed” you do realize the swamp factor term in the equation is nearly completely arbitrary… It’s just helping provide a minimum exposure time that sets the average of the frame above the read noise, it’s not actually telling you much about how you’re actually exposed, you can still be underexposed or overexposed depending on what the target actually is.
It’s the same as losing shadows or highlights in daylight photography even if the mathematical camera metering is saying you’re good… Sometimes you aren’t… Stacking makes it more complicated
Shooting for 2890 doesn’t mean one of those nuclear orbs isn’t blowing things out, and it doesn’t mean you’re pushing deep into the ultra dim areas very quickly either…
I think it’s important to understand what the math is and isn’t telling you. It’s just a simplified (in some cases way oversimplified) way to give a general idea where your average stack noise will be with regard to background (sorta - because the object is included in the average) levels and read noise, which is more applicable to imaging with very heavy light pollution giving the shortest times you can get away with… So they aren’t “optimal” as there’s no such thing, there’s too little and too much and the gap between those is sometimes huge, like under a second to over 20 minutes just depending on the situation…
‘So there’s no upper limit to capture ultra dim things (real cameras have practical limits) and the brightest area of the target sets when you’re going to clip high… neither of those things are really considered in Dr Glover’s math. In some cases you’ll actually need multiple sets of exposures to bracket enough dynamic range to capture things like the Orion Nebula… Actual space gets ridiculously dark right next to extremely bright things pretty often, so having a range of settings in your quiver is pretty useful…
Just throwing a point of view out there so you aren’t held hostage in a little box of mathematical constraints…
One practical point is maybe a few blue stars are now white, but you don’t have 36 quintillion subs on your hard drive, eh not so easy to find the optimum… Might not matter today, but 200TB later you realize those blue stars are expensive lol…
Edited by Robert7980, 16 April 2024 - 02:32 AM.
