Tom, Scott, and Mike, thanks for the notice. Also, I appreciate the likes.
As for the Z8 and lunar imaging, it's a pretty good combination since its stacked CMOS sensor allows full-frame, RAW burst rates of up to 20fps (using the camera's internal memory buffer) and it has a fully electronic shutter. During last night's session I averaged about 14fps over two minutes of capture but I was using a 1:1 format (5504x5504 pixels) rather than full frame (8256x5504). In any case, I'm not using the fastest CFExpress card that you can buy and some people report being able to do sustained 15 to 20fps even in full frame (although I think the 20fps reports are highly suspect).
In terms of image quality, the stacked sensors don't seem to offer quite the same merit that you can get from a similar-sized, similar-generation CMOS counterpart but I doubt that matters much for lunar imaging. For DSOs I'm still not certain whether or not this camera is fully usable since it seems to suffer from the same colored, concentric ring problem as do all recent Nikon cameras. Under some conditions the latter doesn't seem to be a significant issue, in other situations (subject, sky brightness, exposure, vignetting) it can cause problems (or so it seems from my limited use).
One aspect on the Z8 that I still want to investigate is its ability to do pixel-shift captures. I suspect that it might be useful for extreme wide-field work with short-focus camera lenses since the 4.34um pixels on the Z8 don't really sample stars that well under those conditions (with a good lens). Basically you'd use the pixel-shifting to produce a guaranteed dither and then drizzle the subs. However, a 2X drizzle would produce a 180 megapixel output which is getting a little much. Unfortunately, I don't think the pixel shifting would offer any real benefits when imaging with a scope since at that kind of scale the seeing conditions would be moving the image around more than the pixel shifting itself. But it does offer an easy way to do accurate 1 to 2 pixel dithers on your captures. In any case, I'm waiting for the day that we can have a dedicated astro camera that has sensor shift capabilities built-in since it makes a lot more sense to move just the sensor than the entire mount and telescope during fine guiding. And, one would hope that sensor shift technology would be much cheaper than today's AO units.
One of the reasons I was using the reducer was that my EdgeHD was still setup for some work I did on earthshine a few days ago ( __HERE__ on CN) and in any case I wanted to see how it would perform on DSOs. I still need to get a so-called "wide" T-adapter since the M42 variety I have now vignettes pretty badly (on the full-frame Z8). However, if it is clear tonight I may switch back to the f/10 focus since the moon is getting a little bright for DSO work. I suspect that the results at f/10 will be even better than you might expect just from the change in the image scale since Celestron's 0.7X reducer isn't really known for providing top-notch image quality.
Edited by james7ca, 16 April 2024 - 11:17 PM.
