ASI294MM -- Simplifying Flats
6 replies to this topic
#1 sternenhimmel
sternenhimmel
Posted 16 April 2024 - 02:29 PM
I'm starting to get a hang of taking flats for my ASI294mm, but it's still a bit of a chore and I'm wondering if there are ways to improve the process at all.
Because the ASI294mm sort of requires exposures to be >= 3s, I can't use the autoexposure feature to take my flats. My current procedure looks something like this:
  • Take white pillow case folded X times and place atop aperture.
  • Take tracing pad with adjustable brightness set to Y brightness on top of the aperture.
I then tune X and Y depending on what filter I'm shooting through. For Luminance, I usually need 8 or 12 folds in the pillow case and the brightness setting to be at it's lowest to get something reasonable. For narrowband, usually 4 folds and the brightness somewhere in the middle. RGB somewhere between these settings.
Last night I shot, L, RGB, and some narrowband, so taking flats required a lot of hands on adjusting between sequences, rather than just being able to walk away.
I don't think there's an easy way out here, but thought I would ask.
#2 dswtan
dswtan
  • Loc: SF Bay Area, CA
Posted 16 April 2024 - 03:30 PM
I have multiple years on 2 concurrent ASI294MMs and haven't needed to be strict on the >3s "rule".
I've previously posted numbers using an "Amazon cheap tracing panel", and a folded white t-shirt through f/4.8 and f/7, using the NINA wizard and auto exposure:
https://www.cloudyni...ats/?p=13091167
0.03s and 0.11s on L
up to
2.8s and 13.53s on SII
It does appear though that "YMMV", perhaps with panel and filter variables. Also t-shirts. :-)
What I'm saying is -- have you just tried with shorter numbers and seeing how it goes? It works (two different cameras) for me...
#3 Drothgeb
Drothgeb
  • Loc: Maryland
Posted 16 April 2024 - 06:14 PM
I have an adjustable tracing panel, and shoot 0.5 sec dark flats. Then just make sure the flats are 0.2 to 0.8 sec. Works for my 294 MM and MC.
#4 Oort Cloud
Oort Cloud
  • Loc: New Jersey, USA
Posted 16 April 2024 - 08:20 PM
https://www.amazon.c...ef=nb_sb_noss_1
#5 psienide
psienide
  • Loc: Frisco, TX
Posted 16 April 2024 - 08:38 PM
I just take my flats against a dimly lit wall. Works fine. I tried flat panel and found that it was way worse.
#6 sternenhimmel
sternenhimmel
Posted 17 April 2024 - 11:29 AM
Interesting. I actually don't know in what ways the 294mm behaves badly with short exposures, I just heard that it did. If I can shoot down to 1s, that would actually alleviate most of the need of adjusting the pillow case.
#7 CharLakeAstro
CharLakeAstro
  • Loc: 44.5N
Posted 17 April 2024 - 06:53 PM
Review the linked thread below...
JohnnyBravo collected 294mm data which shows more than 1.5sec, gives linear response. Less than 0.8sec is slightly linear. Safest bet is 2 sec for flats. Using 1 sec would be the worst area for non linearity.
https://www.cloudyni...elp/?p=11040561
  • jdupton likes this
