Altazimuth mount+ refractor without tremors?
32 replies to this topic
#1 paulsky
paulsky
Posted 16 April 2024 - 04:06 PM
Hello,
Does anyone know if an altazimuth mount can really adequately support a 4" F/7 refractor, that is, allowing us to see the image without vibrations or tremors?.. With high magnification...
Thank you
Paul
#2 ButterFly
ButterFly
  • Freeware Developers
Posted 16 April 2024 - 04:48 PM
Did you have a particular altaz mount in mind, or is this a general question?  An adequate mount will do fine.  An inadequate one won't.  Posting a budget is also a good idea.
I use my Manfrotto 475B with an N12 head with my 120mm f/7.5 with a 3-6 Nagler for planets.  It's not good when it's windy.
If you want tracking and goto, a Skywatcher AZEQ5 will do fine. iOptron also makes a few.  Their strain wave mounts are incredibly light weight.
#3 cst4
cst4
Posted 16 April 2024 - 05:12 PM
I use a SV M2 mount head... with the right tripod, it is absolutely vibration-free with my 4" F/7 at all magnifications the scope can muster.
  • jimandlaura26, Kutno, Lookitup and 2 others like this
#4 Mark9473
Mark9473
  • Loc: 51°N 4°E
Posted 16 April 2024 - 05:15 PM
My Berlebach Planet + DiscMount DM6 do that admirably. Settling time after a hard knock is just a fraction of a second. That's with my APM 107mm apo or my Mewlon 210.
#5 Sketcher
Sketcher
  • Loc: Under Earth's Sky
Posted 16 April 2024 - 05:21 PM
Of course, it's possible for an alt-az mount to adequately support a 4-inch f/7 refractor!  Below is a 6-inch f/6.5 refractor that's adequately supported by a (homemade) alt-az mount:
6 inch Alt Az
But my personal preference, by far, is to use a German Equatorial Mount (GEM) to support refractors for visual astronomical use -- regardless of magnification.  That 6-inch f/6.5 refractor once again:
6 inch On GEM In Colosseum
In my opinion (an opinion that few seem to share) alt-az mounts are better for terrestrial refractor use, but GEMs are better for astronomical refractor use.
  • Alterf, dwmedic and pcrichmond like this
#6 pcrichmond
pcrichmond
  • Loc: Bishop CA
Posted 16 April 2024 - 06:11 PM
I use a Sergio Bonilla dual alt/az with the SW 100/9 Evostar or a combo of a C6 and short tube 4" refractor for grab and go star hopping.
Settling time is minimal, really like it for an alt/az mount. Run it on an Ioptron tripod with 1.75" legs
For longer observing periods with the larger SW 4", I'll usually set up a Gem.
  • ancleto likes this
#7 richardr
richardr
  • Loc: Seattle, WA
Posted 16 April 2024 - 06:23 PM
I use an f/9 4" on a Stellarvue M002C with a Vixen wooden tripod and it is stable unless there is wind.  It is very stable with an f/6 3" telescope that is old and heavy(about 6.6lbs. without rings and vixen plate) or 10lbs. all up.)
  • doctordub and Kutno like this
#8 John Huntley
John Huntley
  • Loc: SW England
Posted 16 April 2024 - 07:52 PM
I use either a Skytee II or a Giro Ercole mount with my 100mm F/9, 102mm F/6.5 and 120mm F/7.5 refractors. I can usefully use 300x magnification with these setups.
#9 RazvanUnderStars
RazvanUnderStars
  • Loc: Ontario, Canada
Posted 16 April 2024 - 07:53 PM
"without vibrations or tremors" - the tripod is critical. A well made mount on a tripod too light will still vibrate.
In my case a Berlebach Planet is rock solid to keep my 120mm refractor.
  • therealdmt, Lookitup, kksmith and 3 others like this
#10 Mike Q
Mike Q
  • Loc: Monnett Ohio
Posted 17 April 2024 - 04:29 AM
I use an iOptron AZ mount pro.  I put the tripod on the anti vibration hockey pucks and have no issue with vibrations at all.
#11 ancleto
ancleto
  • Loc: Alabama
Posted 17 April 2024 - 07:41 AM
I use a Rowan AZ100 on a carbon fiber surveyor’s tripod. it’s big, it’s heavy…but it has very little vibration.
I use the rowan for a 127mm F/7.5 triplet refractor (25 lbs).
I have a Sergio B mount that works well for a little at80ed refractor or my c6. I take it camping or when I want a light, quick setup.
Edited by ancleto, 17 April 2024 - 07:31 PM.
#12 Scott99
Scott99
  • Loc: New England
Posted 17 April 2024 - 11:31 AM
Hello,
Yes it can
#13 Lentini
Lentini
  • Loc: Alexandria, Virginia
Posted 17 April 2024 - 11:54 AM
I have a 4" F/7.4 and a much more difficult 80mm F/15.
The two mounts I use are excellent for vibration free use for both. But I had to upgrade to these tripods to get to zero settle time. Bang on them, and they don't vibrate.
Note an extension pier even with these mounts and tripods still left a little wiggle with the F/15. So I use the F/15 with the DM4 and no extension pier. Rock solid.
Note that weight capacity and vibration resistance aren't linear. I had a carbon fiber tripod that could hold 65lbs... But the top of it had azimuth wiggle with longer scopes that these Oberwerks don't have.
But to your question...  Yes, the 4" F/7.4 is stable with or without extension piers on both of mine, and had been with many other alt-az mounts (and tripods) that I tried previously.
#14 John Huntley
John Huntley
  • Loc: SW England
Posted 17 April 2024 - 12:58 PM
This combo was really rock solid - T-Rex + Tak FC100-DL:
  • Kutno, Lookitup and rksturm like this
#15 Lookitup
Lookitup
  • Loc: SW Germany
Posted 17 April 2024 - 01:05 PM
Tak 100Df with NOH CT-30. Not "rock" solid though due to the light weight CF tripod. Panning and focusing is less than 1/2 a sec.
  • John Huntley and JeremySh like this
#16 db2005
db2005
  • Loc: Denmark
Posted 17 April 2024 - 02:30 PM
Very capable Alt-az mounts do exist, but the irony in the current market is that strong EQ mounts tend to be less expensive than strong Alt-Az mounts, especially if you want slow-motion controls, which you probably want for high magnification observation
And for heavy scopes most alt-az mounts require counterweights, meaning that they negate one of the key advantages of alt-az mounts: low weight.
I've owned several alt-az mounts over the years, and my favorites by far are the Vixen Porta II and the Vixen APZ. The Porta II isn't beefy enough for a 4" f/7 IMO, but the APZ is significantly stronger.
  • John Huntley and ancleto like this
#17 Lookitup
Lookitup
  • Loc: SW Germany
Posted 17 April 2024 - 02:43 PM
Tak DF on TS-Optics Tri-Pier and Supermount M Standard without any tremors.cool.gif
Edited by Lookitup, 17 April 2024 - 07:01 PM.
#18 Scott99
Scott99
  • Loc: New England
Posted 17 April 2024 - 04:02 PM
Discmounts, Supermount no counterweights and work great waytogo.gif  But I agree, if I'm using counterweights, I'll be using a traditional EQ mount.  In fact I've got Teegul, DM6, and W-Master, all three with no possibility of counterweights smile.gif
One thing I'm still learning is the effect of the unbalanced load on tripods.  It means you need to use a larger, beefier tripod for the same load.  Tripods can take more weight when it's balanced evenly.
Edited by Scott99, 17 April 2024 - 04:24 PM.
  • db2005 likes this
#19 Lookitup
Lookitup
  • Loc: SW Germany
Posted 17 April 2024 - 05:33 PM
Actually M12 counter-weight works with my M Standard. Here is a pic with the M10 bar only with M12 adapter.
  • Scott99 likes this
#20 dryfly
dryfly
  • Loc: Maine
Posted 17 April 2024 - 05:34 PM
I had a DM-4 on a Berlebach Uni-24 for my Tak FC100-DF and it was so solid a hurricane couldn't budge it.  I also used it on a AZ Mount Pro, and found that mount very good as well.  Lastly the Super Mounts W and M mounts are excellent as well.
  • Lentini likes this
#21 Lookitup
Lookitup
  • Loc: SW Germany
Posted 17 April 2024 - 05:45 PM
I did like the DM4 a bit better vs the M Standard with the Tak DF and binoviewer. Favorite so far is the NOH CT-30 and soon the CT-20. With a ED125 the NOH was clearly more stable. CS Pete
  • Scott99 and dryfly like this
#22 sevenofnine
sevenofnine
  • Loc: Santa Rosa, California
Posted 17 April 2024 - 06:40 PM
Consider this one by Sky-Watcher. It has both EQ & Alt/Azimuth plus dual encoder technology borg.gif
https://www.skywatch...products/az-eq5.
  • ABQJeff likes this
#23 ABQJeff
ABQJeff
  • Loc: New Mexico
Posted 18 April 2024 - 09:31 AM
+1 and dual scope capability to boot.
Or better yet if you REALLY want a rock solid mount for a 4” scope: the Az/Eq-6.
And a Panther TTS-160 will also be rock solid (not to mention the Mammoth TTS-300!)
Bottom line, there are many alt-az mounts that can hold a 4” refractor rock steady, like it isn't even there.  But there is a cost and convenience price to pay for the biggest of them.
Most people get a 4” refractor for grab and go.  That necessitates a smaller mount as well, and thus the real challenge you are facing.  “Is there a light weight grab and go mount that can hold a 4” refractor rock steady?” I think is the real question.  And even there yes; above recommended Rowen AZ100, M2C, Losmandy AZ8, etc. are all good mounts (be sure to put on a steady tripod).
#24 Scott99
Scott99
  • Loc: New England
Posted 18 April 2024 - 10:39 AM
#25 PatientObserver
PatientObserver
  • Loc: Boston, MA
Posted 18 April 2024 - 04:43 PM
I may need to look into a counterweight bar for my S-Mini.
